Chain sharpening station
Discussion in 'Chainsaws and Power Equipment' started by Osage Orange, Jan 15, 2015.
  1. MasterMech
    I still want to try a dust collector setup for my USG. It turns the bench it's mounted on into a mess pretty quick.
    Firewood Bandit likes this.
  2. Moparmyway
    Moparmyway
    New York
    My sharpener (511a) is mounted on an old header made from (2) 2x8's
    Its about 4 feet long so I can attach it to any vise I am around, at home, at work, etc..
    In the field I use a big "C" clamp to hold it to something, or bolt it to a tree with a couple of lag bolts
    Its the easiest, most universal setup for me !
  3. Moparmyway
    Moparmyway
    New York
    Don't the diamond or ABM wheels make less mess ?
  4. MasterMech
    Still running the ones that came with my USG. I've about worn out the first set and I have one more. I want to try the diamond wheels but they just aren't in the budget at the moment.
    Cut4fun likes this.
  5. HittinSteel
    HittinSteel
    Wooster, Ohio
    Here's my setup :)
  6. Moparmyway
    Moparmyway
    New York
    I hear you ............ I have about 7 or 8 wheels left (probably last me at least the next dozen years) for 3/8 on my 511a. Then I will probably have enough scratch to get a diamond wheel for it.
    I have not been using my sharpener lately, except to use the rails to set rakers ................ filing by hand indoors takes over in the slower and colder winter days.
    I need a chain vise from homey:thumbs:
    clemsonfor, Chvymn99 and MasterMech like this.
  7. Moparmyway
    Moparmyway
    New York
    That looks like it transports real easily !!
    HittinSteel likes this.
  8. HittinSteel
    HittinSteel
    Wooster, Ohio
    Yes, nice mobile setup.....works even better on a tailgate!
    Moparmyway likes this.
  9. jeff_t
    jeff_t
    SE MI
    One of these days, I'm gonna make up a stand and mount it to the floor. Nothing special, just some substantial square tube with plates welded on each end. That'll keep the mess off the bench and easier to clean up, and fabbing a dust collector should be easier, if I think I need to.
    Got nothing special at the moment, just bolted to the corner of a bench. Not even worth a picture.
  10. DexterDay
    Nice! !
  11. Cut4fun
    Cut4fun
    OHIO Redneck
    Hand filing I like on the bar in rotating vise. I dont bench mount my USG grinder, it is on the wall out of the way and chains can hang down.
    Dougr6, DexterDay and Chvymn99 like this.
  12. Firewood Bandit
    Firewood Bandit
    I thought about setting up a dust collection system. But to do it right it needs to be ducted outdoors to keep fine particulates out of the indoor air.
  13. dgeesaman
    dgeesaman
    Elizabethtown, PA
    I like your setups. I inherited a "chainsaw" workbench when I bought my property. Old Neilsen grinder doesn't have many adjustments but it cleans up a .325 chain beautifully. After sharpening 3 chains yesterday I am definitely ready to remount it right at eye level.
  14. Firewood Bandit
    Firewood Bandit
    Just make sure you wear some eye protection.:binoculars:
    One more tip I forgot about. The Tecomec and Oregon style grinders have way too much travel in them. So I took a blue shoelace, (you can see in pics) to stop the grinder head from extending all they way. When you grind, now you only have to move the grinder about 3" rather than 8".:)
    Osage Orange likes this.
  15. w8ye
    w8ye
    Mansfield, Ohio
    The most effective, cheapest, and passive dust collector for your chain grinder are a couple big magnets setting on top of the mounting bolts. I like the ones like come off the wave outlet of a magnetron tube of a microwave oven or something that size.
  16. Firewood Bandit
    Firewood Bandit
    I just bought the cheap welding magnet fixtures at Horrrible Freight.
  17. w8ye
    w8ye
    Mansfield, Ohio
  18. redneckdan
    redneckdan
    Northern Minnesota
    If anyone needs some kick azz magnets shoot me a holler. I can get them from work cheap. We use them for temporary pipe line patching. I can stuff a couple in a flat rate box for about $5 shipping. Just don't get your fingers between the magnet and steel, give it room to run and it will honest to god break your fingers.
  19. Smokinpiney
    Smokinpiney
    "South" Jersey
    Here's my state of the art sharpening station
    Chvymn99 and dgeesaman like this.
  20. chris
    here is my set up, the 511ax's are set one for right and one for left, with the old Foley doing the depth gauge work.
