Pellet Furnace
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by boettg33, Jan 16, 2015.
  1. boettg33
    boettg33
    Wakefield, RI
    For those running a Pellet Furnace, do you have a weekly/monthly cleaning procedure to keep them running optimal like a Pellet Stove? Or are they more forgiving than a pellet stove?
    ivanhoe, wildwest and Gasifier like this.
  2. Gasifier
    I'm interested in this as well. I almost went with a Pellet furnace instead of a Pellet stove for camp. But the money was the big factor. Less than half the money invested in stove.
    ivanhoe and wildwest like this.
  3. Gasifier
    But obviously, looking back on it, if the furnaces are easier to clean and not so finicky then it would have been worth it to get the furnace.
  4. mithesaint
    mithesaint
    NW Ohio
    I'm on my first season with a brand new St. Croix SCF 050. I'm burning straight shelled corn for the first time as well. So far, I haven't been that crazy about cleaning it. I've burned well over a ton of corn so far, and I've cleaned it once. I need to take some time and really tear it apart and learn all the cracks and crevices and nooks and crannies, but I haven't done it yet. I really really really like having a furnace. If you're between a furnace and a stove, go with the furnace. That said, I also have a free standing stove that I can turn on if it gets really nasty outside, or if I need to shut the furnace down for whatever reason. My free stander (Englander 10-CPM) also is automatic, so I can shut the furnace off on decent days and let the CPM heat if it's not too cold out. I really like the redundancy of the stove and furnace setup.
    ivanhoe, imacman and IHATEPROPANE like this.
  5. DexterDay
    I go extended periods on both my Pellet units. My freestanding and my Pellet furnace. Because my Fahrenheit Endurance 50F is self cleaning (burn pot), it can go for quite some time.
    The only thing that may need cleaning once, is beneath the pot. There is a trap door that opens and let's any ash build up drop out. But I am almost positive that this unit can an entire season just emptying the ash pan and pulling the heat exchanger rod once a week or so.
    There is 18 heat exchange tubes ( I believe the SCF-050 has 18 as well). Half the air comes through those tube and the other half is blown around the outside of the actual firebox to pull the heat from it. It's then mixed before it shoots out the top.
    I love my furnace. Been abusing it for 4 years and every year I push the limit a little further. :D
    ivanhoe, imacman and Gasifier like this.
  6. 343amc
    343amc
    Northeast Lower Michigan
    I dump the ash pan every week or two. I dumped it a week ago today and it was only half full. It's fairly warm today, so I'll shut it down and dump it again today. If it's cold out, and I don't want to shut it down, I'll dump it every couple weeks.
    Every ton or so (4-6 weeks this time of year) I give it a more in depth cleaning and hit the venting with the leaf blower. Once a year it gets the full cavity inspection. :)
    ivanhoe and DexterDay like this.
  7. DexterDay
    Would you agree the furnace can take a longer beating than a standard freestanding stove? At least the self cleaning furnaces.
    The ash pan on the Fahrenheit is pretty big, but it is the week spot. It needs the most attention.
    But this furnace is so easy to operate, that my wife would probably sell the upstairs pellet stove (has a touch screen control panel) and the wood stove if something ever happened to me. This would be what she kept and operated. She knows as long as it is fed and ash is empty? Then she just sets the stat and stays warm.
    I love our upstairs stove.. :) But keeping the whole house an even temp? Impossible. . It is in the center of the house and that room has to stay 78° to keep the rest of the house 70°.
    ivanhoe, 343amc and wildwest like this.
  8. wildwest
    The back end of our house is much cooler than where our stove is. They are two bedrooms. Electric ceiling bar in the lil one's room that we keep at 65*
    ivanhoe likes this.
  9. 343amc
    343amc
    I spend nowhere near the time cleaning the furnace as I did cleaning my 6041. I had to do an in depth cleaning every week on that stove just to keep it going. The furnace is nowhere near as difficult to clean.
    The main reason I do a quick cleaning once a week is due to my goofy work schedule. If I end up being out of town unexpectedly for a few days, I want to know that my wife won't have any problems with the furnace. Well, problems that could be attributed to cleaning issues anyways.
    Today I shut it down at 3 PM. Went to the grocery store for a few things, came back, did a quick clean, had a fire again at 4:10 PM. Only about 20 minutes of that was actually working time. :)
  10. boettg33
    boettg33
    Wakefield, RI
    How many tons of pellets do you the Pellet Furnaces use on average? I recently replaced my 20+ year old oil burning furnace with a new one. However; we are looking to put a pellet stove in the downstairs to supplement. In order to keep the downstairs warm enough, we heat ourselves out of the second floor.
    ivanhoe likes this.
  11. DexterDay
    Is the wood stove enough for you upstairs living area? Or is the pellet going to supplement?
    If supplemental? Then a freestanding would probably work? But if you are looking for quite a bit of help? A furnace is the route to go..
    Some freestanding stoves clean better and need less attention. So it's all in what you need
    ivanhoe likes this.
  12. imacman
    imacman
    Denver, NC
    boettg33, most pellet burners use 3-4 tons in a "normal" winter. Since you're just looking for supplemental heat, probably wouldn't be that much....maybe 1 - 2 tons?
    343amc, ivanhoe and wildwest like this.
  13. DexterDay
    I burn about 1-2 ton a year in my furnace. Last year I burned 2 ton in thr furnace and about 1.5 in my freestanding stove upstairs. But that was a bad winter. The previous 2 winters to that, we're 1 ton in each stove.
    ivanhoe, wildwest and eatonpcat like this.
  14. Dana B
    Dana B
    Southern New Hampshire
    When you say pellet "burner" what are you referring to? A stove, furnace, boiler?
    I don't think it's fair to make a general statement like most pellet burners use 3-4 tons in a normal winter. there are far too many variables from one indivdual's situation to another. I have a pellet boiler and I'm averaging between 5-6 tons per heating season.
    I have a Windhager Biowin and it's been great. I generally only have to clean it after every 3 tons burned and the cleaning is pretty straightforward and quick to do.
    The only pellet furnace I'm aware of is the on made by Harmann. I looked at their pellet boiler and was not impressed when compared to the competition.
  15. imacman
    imacman
    Denver, NC
    Dana B
    Not fair???? Sheesh, calm down. :picard: I'm pretty sure most of the pellet burners on this forum (or any other) , understand what I was referring to. I would feel safe saying that MOST pellet burners that now use a furnace or boiler, originally started with free standing or insert stoves.
    Please notice that I said the word "most", not all. Making a general statement in this situation is perfectly acceptable, since I have no concrete numbers to go by. Neither do you.
    As I highlighted above, MOST pellet burners use free standing units to supplement their existing heat as much as possible. While their use is increasing, pellet furnaces and boilers are still in the great minority.
    So, I am saying that since free standing units are the great majority, 3-4 tons is a perfectly acceptable number. Furnaces & boilers could use more or less, depending on location & whether or not it's the only heat source or not.
    Happy now?
  16. eatonpcat
    :handshake:
    I'm hoping 6 ton will be enough for me this year...How will this effect the average?? :whistle:
    ivanhoe, wildwest and imacman like this.
  17. wildwest
    and some have demanding wives that need it way warmer than most homes :emb: so they go through a lot more pellets.
    ivanhoe, SmokeyTheBear and eatonpcat like this.
  18. imacman
    imacman
    Denver, NC
    Gee.....I wonder who that might be? :whistle: Do they have cast iron skillets?
    ivanhoe, SmokeyTheBear and wildwest like this.
  19. Dana B
    Dana B
    I wasn't unhappy before.
    I just wanted to make the point, as we all know, that the amount of heating fuel used in a season, whether it's pellets, cordwood, oil, lp etc etc is subject to so many different variables such as the size of your home, insulation and air sealing, how warm you like it etc etc etc
    I think I misunderstood what you meant when you said pellet burner? I took it to mean that you were using the word "burner" to refer to a pellet burning appliance but now I see that you were actually referring to a person who is burning pellets.
    I considered a stove or insert before I bought my boiler but it just wouldn't have worked in my home so I went straight for the boiler. I like that it ties into my existing baseboard and provides central heating as opposed to the radiant heat of a stove.
  20. wildwest
    I've asked for a skillet swinging smiley, I think he's afraid to give me one here.
    ivanhoe, SmokeyTheBear and imacman like this.
