Seasoned or not
Discussion in 'The Wood Pile' started by Woodrat1276, Jan 18, 2015.
  1. Woodrat1276
    Woodrat1276
    Ky
    What's your opinion seasoned or not.
    fox9988, Pallet Pete and wildwest like this.
  2. Horkn
    I say not, but only a moisture meter can tell you
    Pallet Pete, oldspark and wildwest like this.
  3. Horkn
    Otherwise, I hear Yukon Cornelius can taste if it's seasoned or not.
    milleo, schlot, Woodchuck and 4 others like this.
  4. prell 73
    prell 73
    ia
    Need to split it and check the fresh split with a moisture meter. To tell for sure.imo
  5. Tsquini
    Tsquini
  6. Woodrat1276
    Woodrat1276
    Ky
    Well it's seasoned it's actually ten years old. It has been in a barn since the day it was cut. The surprising part is it does look green it still has the weight of green wood yet it burns like gasoline.
    Backwoods Savage, fox9988 and NH_Wood like this.
  7. Paula
    Paula
    UK
    Not. The bark on the end hasn't even started to separate yet.
  8. Gark
    Gark
    SW Michigan
    Don't see any 'checking' cracks on that end cut. Another hint for not dried, but not definitive either. Moisture meter on freshly exposed split surface is your best way to find out.
  9. Paula
    Paula
    UK
    What wood is it?
  10. Horkn
    Crazy. 10 years drying and no real checking and the bark stayed on? What kind of wood is that?
  11. Locust Post
    I'd say it's dry but I don't see any salt or pepper on it, so it's not seasoned.
  12. Woodrat1276
    Woodrat1276
    Ky
    I was really doubting it when I first picked it up. The weight and color says its green so I had to try it. Hesitently I burnt it separate just to see. It's ash and hickory I was there the day it was put in the barn 10 years ago I don't understand how it could look like the day it was cut yet burn unbelievably good
    Backwoods Savage, Paula and Horkn like this.
  13. Woodrat1276
    Woodrat1276
    Ky
    I promise it's ten years old they used to be tier poles that held tobacco for curing. I'm going to get more ill take some pics so those who don't know what a tier pole is will get a better understanding
  14. Paula
    Paula
    UK
    What a great find then.
    Yes, all the tried and tested oldie methods aren't always true. (I LIKE being old and tested dammit!)
    Id have put money on not being able to burn that for a good 12 months without checking with my MM.
    Shows what can be (un)told by eye alone :D
  15. Woodrat1276
    Woodrat1276
    Ky
    That's with the dampener turned almost all the way down
  16. prell 73
    prell 73
    ia
    I agree.
  17. Paula
    Paula
    UK
    You'll be posting a pic of toasted crumpets next :)
  18. Woodrat1276
    Woodrat1276
    Ky
    I would have said the same thing Paula in fact I did I was like how in the world is this stuff still heavy like this. It was baked in a barn a tobacco barn is made to cure. If I wasn't there ten years ago to see it put in I would have stacked and let it cure with the rest of my wood.
    Backwoods Savage and Paula like this.
  19. NH_Wood
    NH_Wood
    This is funny - goes to show a pic can't always give good info on the dryness of wood - which makes sense. I've had red oak in the stack about 18 months that was dark gray and checked - a photo would have said 'perfect', but once split the center of the large splits still pretty wet. I bet those rounds are burning awesome!! Cheers!
  20. Horkn
    I knew it...
    Paula likes this.
