Your nc30 needs a convection deck
Discussion in 'Modern EPA Stoves and Fireplaces' started by Highbeam, Jan 17, 2015.
  1. Highbeam
    Highbeam
    None available from Englander, but the one on my bk kicks butt so I made one. What do you think?
    Big difference in blasting heat into your face when sitting in front of the stove. So now I wonder about upgrading the silly ac16 blower to something else.
  2. Highbeam
    Highbeam
    Stupid picture upload process...
  3. fox9988
    fox9988
    NW Arkansas 72717
    Looks factory. Nice
    blacksmith and raybonz like this.
  4. cnice_37
    cnice_37
    Looks great. Were your keys cold?
    New house?
    blacksmith and Mitch Newton like this.
  5. Highbeam
    Highbeam
    Always put my keys there. They can get warm which is a little unpleasant in your hand but can get real exciting when I drop them in my pocket.
    This is the shop stove, a permitted install in my pole barn. When I run the stove out there it is for max heat for a short time doing whatever I can to safely produce max heat. No cruise or long burn times.
  6. papadave
    Is that angle iron underneath?
    I keep thinking of doing that.
    The other blower does a great job, but when I kick it up to more than about 25% above the lowest setting, it starts getting a bit noisy. I've never had it much above that point.....don't need it.
    Does a real good job moving the air.
  7. papadave
    Oh, and that does almost look "factory".
    Very nice cuts......how were those made?
    clemsonfor and raybonz like this.
  8. HDRock
    Really nice job there Highbeam, :thumbs:
  9. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Made a convection deck for the BKK a while ago, made a difference. I'm a fan of directed heat, good job.
    HB, nice install, very clean appearance.
    raybonz and papadave like this.
  10. Highbeam
    Highbeam
    The sides are 15.25" long, .125" wall, square tube. I chopped it with a chopsaw and then custom fit the back around the heat shield with an angle grinder.
    The top sheet is 18"x24" sheet aluminum sign material cut with a jigsaw and corners rounded with the angle grinder.
    Pop rivets and self tappers.
    I thought about just folding the edges of the top sheet but didn't think I could do it with precision.
  11. Scotty Overkill
    Looks damm good! You should whip up a bunch of them and put them on ebay!!
  12. papadave
    Thought the same thing Scotty.
    Heck, I'd consider buying one.
  13. Todd 2
    Todd 2
    Looks great, You did a clean looking job. Can you tell a good difference with it heating up the shop from a cold start ?
    blacksmith and clemsonfor like this.
  14. Highbeam
    Highbeam
    Just made it today and cured the paint. Big football game tomorrow. Hope to burn it hard on Monday to see how she does. The blast of air coming forward is significant now where I couldn't feel it at all before. If need be I could slide additional tubes under the deck sort of like a pellet stove heat exchanger.
    The ac30 blower is 165$ or I could use a 4x10" duct boot and a 6" inline duct booster fan for 160 cfm under 50$. Might be my next shop project.
    blacksmith, Todd 2, papadave and 2 others like this.
  15. Beetle-Kill
    Beetle-Kill
    Don't think any additional "tubing" would help much, if inserted between the stove and new deck. Might help with channeling the air flow, but not with heat retention.
  16. Highbeam
    Highbeam
    It would be additional heat exchanger area. Think air cooled engine.
    papadave likes this.
  17. Beetle-Kill
    Beetle-Kill
    It'd be worth a try, just don't see it being noticeable.
    Steel just doesn't retain heat much, with a constant airflow flowing over it. Not a bad thing.
    The small area you'd have heated with a series of tubing might give you a bit more heating, but better would be to have those tubes splayed out in a 70-90'degree pattern. That would be a nice heat dispersion pattern.
  18. DaveGunter
    DaveGunter
    I'd buy one too. I don't have the skills to accomplish that.
    Scotty Overkill and raybonz like this.
  19. raybonz
    raybonz Moderator
    Carver, Mass.
    That looks excellent HB! Paint those screws with the same black paint and you'd never know that was an add-on!
    HDRock and papadave like this.
  20. KaptJaq
    KaptJaq
    Long Island, NY
