Stihl 461 info
Discussion in 'Chainsaws and Power Equipment' started by $ooline, Jan 15, 2015.
  1. $ooline
    $ooline
    WI
    Gonna pick up a 461 in the next couple weeks. :D I've read plenty on this one, really looking forward to getting into the over 60cc category. No plans to have it ported for the forseeable future and read a muffler mod really doesn't do much overall....this true? Would it be worthwhile to put a 460 DP on the 461. I read they will fit fineI believe, not sure though? BTW I'm gonna go with a 20" ES bar. Don't need anything above that for now.
  2. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I just got one last month. I'll be curious to see what what the members have to say. The saw is very impressive out of the box - 25" on mine and it ripped some big oak.
    splitoak and $ooline like this.
  3. Gunn
    Gunn
    Plover, Wi
    The DP cover does help. Gutting the baffle out of the muffler really doesnt net a ton of gains if you go the dp cover route though.
    $ooline and Drvn4wood like this.
  4. mike bayerl
    mike bayerl
    I picked one up last Spring. Admittedly, still don't have a whole ton of hours on it. However, in stock form, it is very fun to operate. I was cutting fresh white oak up to 28-30" diameter with a 32" bar and RS full comp and/or full skip, and it handled it. What more can I say. However, I got mine masterminded this fall and now it is neigh on unstoppable. I don't think you can go wrong with this saw, stock or ported, it will do the work! FWIW, I run my 461 with 25" B&C most of the time since I find that my 361 easily handles the 20" in hardwood.
    Glamour shot of the MS461 w/ 32" B&C
    Typical working configurations, MS461 w/ 25" and MS361 w/ 20"
  5. JRSDWS
    JRSDWS
    Central Illinois
    IMO, muff mod including removal of the baffle, as well as swapping the coil for a 460 coil is very well worth the couple of bucks and little bit of time it takes.
    Drvn4wood, Kg461, Mastermind and 4 others like this.
  6. MasterMech
    Does the 460 coil have anything to offer if the saw is stock? What's the 461 coil limited at?
    $ooline likes this.
  7. Chvymn99
    Congrats! Ought to be a heck of a saw. :thumbs:
    $ooline likes this.
  8. Unicorn1
    Unicorn1
    Amarillo, TX
    Nice couple of saws.:)
    $ooline likes this.
  9. mike bayerl
    mike bayerl
    MS461 coil is definitely limited. I think at 13,500 but not exactly sure. When I got mine ported, I also got an unlimited 460 coil to allow it to run at max/ ideal rpms, just north of 14K at WOT.
    Drvn4wood, Chvymn99 and $ooline like this.
  10. NewToStihl
    NewToStihl
    Central Indiana
    The 460 DP cover will fit on your 461. Somewhere in the neighborhood of 75% or so of the 460 & 461 are interchangeable, and the muffler cover is part of that. I can't tell you from experience if the DP cover makes a noticeable difference though. I had a 461 for awhile and spent several days dropping and bucking large trees with it including some ash trees that were in the 3' DBH range. Because of that I spent a lot of time with the 25" bar buried and that bone stock 461 never missed a beat, tank after tank. Frankly, I never really wished it had more power - in a word, it was perfect. Just because I do sip the Kool Aid occasionally I did get a DP muffler cover. I installed it and re-tuned, but never actually ran it before trading the saw off.
    This isn't the biggest tree my 461 went up against, but still a quality gratuitous Stihl shot!
  11. DexterDay
    You can buy an aftermarket can that has a larger stick opening, no baffle/birdcage, and comes with a DP front cover.
    The only thing needed after that would be to trim the limiter tabs on the carb and buy a 460 coil (if you want full potential ).
    Even with a good muff mod, the coil is a good idea. I believe it's limited in the mid 13's as well.
    My 461 will arrive at Cuddle lane tomorrow. :D Looking forward to its return!! :dex
  12. MasterMech
    My mind is stuck on the fact that the saw is going to run 10,000-11,000 rpm in most cuts. I totally get swapping the coil on a ported saw but other than making it easier to tune, I am still trying to figure out what the advantage is on an engine that will not see 13K in the cut.
    Drvn4wood, dgeesaman, raybonz and 4 others like this.
  13. Gunn
    Gunn
    Plover, Wi
    No you're right, these saws aren't going to pull 14k in the cut. I do like the fact unlimited coils saws are easier to tune though.
  14. $ooline
    $ooline
    WI
    Good posts and info...thanks :thumbs:
    Drvn4wood likes this.
  15. $ooline
    $ooline
    WI
    Good to hear...gonna run a 20" and wear myself out doing all firewooding with this beast unless the old timer shows up to cut with his 361:saw:
    Drvn4wood and concretegrazer like this.
  16. DexterDay
    I still like to tune to max RPM.. No?
    If my 460 would only Rev to 13,000 instead of 14,700, would it have beaten the 441's? Not likely. .
    I still want to hear the tune in wood, but I also would hate to blow a saw up because it wasn't tuned and was merely tapping the limiter.
    For the amount that a coil costs? It is worth it. In my opinion. Because even a simple muff mod will allow that saw to run a higher RPM.
  17. MasterMech
    You're power in the cut isn't necessarily related to what you end up with for max RPMs unloaded. I get what you guys are saying about it simplifying the tuning process however.
    Think about this, if you tuned a muffler modded 461 with an unlimited coil, and then swapped the coil back to the limited unit, would it change where your RPMS settle out in the cut? Unless there are timing differences, it shouldn't.
    Kg461 likes this.
  18. mike bayerl
    mike bayerl
    Unlimited coil is just easier to tune ( I need all the help I can get in that arena). Should not affect performance in the cut as far as I know. It will be real interesting when Stihl finally comes out with an M-tronic 75-80 cc saw. Just sayin'...
  19. Gunn
    Gunn
    Plover, Wi
    It probably won't be long before they have a 462 model. Mtronic updated models are coming out often.
  20. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    The more I read into this it it seems a lot like modding the motor/emissions on my truck. Just leave it alone because it works fine..lol.. Little mods like dawgs and oiler are fine.. Guy I know that deleted and tuned his 6.7 has been all over me about doing mine.. He blew his oil out of the exhaust yesterday when he snapped the turbo on a 2014. Ouch..
