Bar Oil
Discussion in 'Chainsaws and Power Equipment' started by Woodchuck, Jan 15, 2015.
  1. Woodchuck
    Woodchuck
    Southeastern Ohio
    What bar oil are you all using? As for me I have always used Stihl oil in all the saws.
    I guess I have never really thought about it. Just bought more when I needed some. I haven't had
    any issues and may never change, but thought I see what your thoughts were?
  2. dgb84
    dgb84
    arkansas
    I buy cheap bar oil and it works fine. They have gallons of milemaster on sale at at woods for 6.99 per gallon. I know it stinks like gear oil but it works fine for what I do.
    For thick oil In the summer I like husqvarna.
    HoneyFuzz likes this.
  3. papadave
    I just wait for the TSC stuff to go on sale and grab a gallon or 2.
    I really need to get a gallon of the winter grade......I recently tried refilling the saw with oil and darn near had to use a spoon to do it.
    HDRock, HoneyFuzz and LongShot like this.
  4. Horkn
    I use the tall timber brand. It's cheap, but as far as I can tell it seems to work ok.
  5. Dascro
    Dascro
    Southwest PA
    I've usd the TSC brand for years. Summer and winter. Never a problem.
    Hinerman, HoneyFuzz and crzybowhntr like this.
  6. Woodchuck
    Woodchuck
    Southeastern Ohio
    When it gets really cold out, I bring the oil inside to keep it from getting too thick.
    At least I can get sawing quickly on a cold morning!
  7. Grizzly Adam
    Grizzly Adam Guest
    LubeForce from Bomgaars.
  8. Woodchuck
    Woodchuck
    Southeastern Ohio
    I had a friend that made his own mix from motor oil and STP oil treatment.
    I'm pretty sure he didn't save any money :loco: :crazy:
    Ron660 likes this.
  9. wood
    wood
    ia
    I like echo bar oil .
  10. NewToStihl
    NewToStihl
    Central Indiana
    I use Stihl BioPlus.
    MasterMech likes this.
  11. tuneighty
    tuneighty
    South Central PA
    I really like the winter grade stihl.
  12. Woodchuck
    Woodchuck
    Southeastern Ohio
    What makes it winter grade? Is it a lighter weight?
  13. tuneighty
    tuneighty
    South Central PA
    The snowflake on the bottle? (Sorry I couldn't resist.)
    [​IMG] Zoom
    This doesn't happen, I presume its a lighter weight. Kinda the difference of remembering to take the syrup out of the fridge before it is needed for the pancakes. Just flows better.
    I
    HoneyFuzz and clemsonfor like this.
  14. NewToStihl
    NewToStihl
    Central Indiana
    It's nice stuff. Before I switched to BioPlus I used it in winter as well. Couldn't tell you how they describe it on the label, but yes, it's a bit lighter and is also less susceptible to thickening in cold temps.
  15. tuneighty
    tuneighty
    South Central PA
    That said, keeping the saws/oil inside the night before a cutting session seemed to work pretty well with the thick husky oil.
    papadave likes this.
  16. PullinMyPoulan
    PullinMyPoulan
    Manistee National forest
    I add Hydraulic fluid to my regular bar oil to thin it works great.
    HoneyFuzz and Ron660 like this.
  17. Woodchuck
    Woodchuck
    Southeastern Ohio
    I've known folks to thin their oil but have never done it
  18. papadave
    Yep, that works well when you have that planned.
    When you go out with someone else in mind, and end up wanting to cut instead, well, it still works but just flows slower.
    Life happens a lot around here, and plans change.:coffee:
    HoneyFuzz and tuneighty like this.
  19. abnemsdad
    abnemsdad
    pa
    I been using the stihl woodcutter bar oil,its not very expensive and works good.
  20. HittinSteel
    HittinSteel
    Wooster, Ohio
    I use whatever winter weight is on sale. I'll pay a premium for premix, but not bar oil.
