What's the best 2-stroke oil?
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Oct 4, 2013.
  1. mdavlee
    mdavlee
    I called motul a few days back and asked what temperaturethe 800 off road is able to be used at and -54°F was when it will separate.
  2. lknchoppers
    lknchoppers
    Lincolnton, North Carolina
    I just use regular gas with methanol in it. I have never had a problem with any of my small engines or chainsaws. I mix Stihl Synthetic 2 stoke in my saws. Leaving fuel in the carbs for long periods is where most problems are. Modified engines may require higher octane or special treatment, that's why I leave my stuff bone stock for reliability.
  3. clemsonfor
    Sad to say I never drain saws or dump 36 month old fuel. One year fuel probably yes. I dont have problems that I associate to these practices. That said I usually use like 92/93 or recently 87 octane and good oil all fuel is NO E gas unless I forget and buy ethanol and then I use it all up quick and dump the rest.
    lknchoppers and mdavlee like this.
  4. StihlHead
    StihlHead
    The wild west
    Methinks you mean ethanol. Methanol will eat aluminum for breakfast. Bad for aluminum engine chainsaws. Veddy bad. If you leave fuel in saws for longer periods of time, just use a good fuel stabilizer. Problem with leaving ethanol mix in anything over time is that it will absorb water, and the gas will go bad, even with stabilizer in it.
    lknchoppers, Sunfish and $ooline like this.
  5. clemsonfor
    I noticed the me than Al too and assumed he meant Ethonol
    lknchoppers likes this.
  6. lknchoppers
    lknchoppers
    oops typo ^^^
  7. Sunfish
    Sunfish
    Success Mo
  8. clemsonfor
    Many say that Lucus is good I didnt get any cause it was smi syn. I also got amsoil delivered to my door for about the same price.
  9. clemsonfor
    I have been running dominant or. Like the red color.
    I just read on some dirt bike forums that many have rusty pasty bearings!o_O I guess from sitting. Not sure their mix ratios though some said it was a big problem in out boards they read too.
    After that and the fact some of my saws sit awhile I may switch to another am soil or k2 or some thing
    mdavlee likes this.
  10. Sunfish
    Sunfish
    Success Mo
    Many say that, cause they are right. :cool:
    Ryan R, $ooline, mdavlee and 2 others like this.
  11. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    X2 !
    $ooline, mdavlee and MasterMech like this.
  12. Ron660
    Ron660
    NW Louisiana
    I can get 110 and 112 octanes where I live anytime or the 87-93 non-E too in NW Louisiana
  13. Sunfish
    Sunfish
    Success Mo
    I tried 100+ octane a few years ago in high comp ported saws and it actually slow em down a little. I've run 91 E-free and Lucas oil since.
    Moparmyway, Chvymn99, mdavlee and 4 others like this.
  14. Ron660
    Ron660
    NW Louisiana
    I've only tested a high octane in my 212psi 660 once. I did several cuts with 93 and then 110 tuned to 4-stroking. It was about a 25" piece of very dry wood - water oak. The 110 cut an average of 11.6% faster. I've wanted to test again but haven't.
    $ooline likes this.
  15. Ron660
    Ron660
    NW Louisiana
    Here's a dyno test Chad did on my ported 660 using his 92 octane and my 110. The 110 showed a slight HP advantage at 10500 and 11500. But the majority showed the 92 was better throughout most of the rpm range.
    Horkn and $ooline like this.
  16. Sunfish
    Sunfish
    Success Mo
    I've seen the chart and was a bit surprise at the time. Not much difference...
    I guess it might also depend on the saws?
  17. clemsonfor
    I was thinking of that chart when he put that post up. Almost mentioned it.
  18. clemsonfor
    For sure it would matter every ported saw can't be the same.
    Horkn likes this.
  19. Ron660
    Ron660
    NW Louisiana
    I have a compression ratio chart showing recommended octanes for known compression ratios. I've calculated different octane recommendations, at my altitude, for different saw compressions. I'll probably start a thread when I get a chance after I do some testing with several saws. So far, I've concluded 110 octane isn't beneficial unless your saw is pushing over 200 psi. I've only conducted one test to prove this.....more tests are needed. I've also calculated the best octanes from compressions ranging from 150 - 220psi. I might be right or completely wrong. More testing will prove or disprove it.
    Chvymn99, clemsonfor, $ooline and 2 others like this.
  20. Sunfish
    Sunfish
    Success Mo
    Be interesting to see your info on this. Most of my saws are around 190 psi, with one at 200, but they are smaller high rpm saws.
    clemsonfor, mdavlee and $ooline like this.
