How much compression does a MMWS have???
Discussion in 'Chainsaws and Power Equipment' started by Evanrude, Jan 11, 2015.
  1. Evanrude
    Evanrude
    Byron, MI
    Enough to do this when you don't use the decomp and it bites back...
    Didn't realize it when it happened. It took me a few minutes to figure it out. It just made it that much meaner when I dropped it in the log. They can't stay pretty forever, I suppose.
    HDRock, bigbarf48, clemsonfor and 5 others like this.
  2. Elderthewelder
    Elderthewelder
    Washington State
  3. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Starting technique is everything. On high compression saws you need to roll it to TDC and then pull it like you mean it.
  4. Evanrude
    Evanrude
    Byron, MI
    Oh trust me, I do. I have a habit of not using decomp on my saws and always tug the rope to the pulse before giving them a firm pull. This one just got the better of me today.
  5. NH_Wood
    NH_Wood
    Dang! Now you have to start telling your buddies a better story - near miss widow-maker, angry beaver, encounter with crazy tree-hugger......Cheers!
  6. Sunfish
    Sunfish
    Success Mo
    I thought Stihl plastic was tougher than that? ;)
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Ouch indeed !!! That should give better airflow now ! Probably runs better now LOL :)
    clemsonfor and Chvymn99 like this.
  8. Chvymn99
    Whoops.... That'll buff right off..:emb:
    concretegrazer and HoneyFuzz like this.
  9. Evanrude
    Evanrude
    Byron, MI
    Me too. Apparently, they don't take well to being punched.
    I was able to pop the pieces back out without breaking any off. I'm going to put some screen on the backside with some epoxy. Hopefully they'll stay in place then.
  10. RJames
    RJames
    Here you go chief!!
    Problem solved, if you can take the verbal abuse:D Sorry couldn't hep' it
    $ooline, clemsonfor, fox9988 and 2 others like this.
  11. RJames
    RJames
    Oh yeah, how's the hand??
    Hope no broken bones, that looked like you hit it HARD!
  12. Evanrude
    Evanrude
    Byron, MI
    Hahah, no need for the massive handle. The saw caught and jumped into my hand - still holding the handle. Like I said, I didn't even know it happened right away. It took me a few minutes to figure out why my saw was like that! My hand is fine, I had good leather gloves on, can't even tell.
  13. RJames
    RJames
    Glad you're ok. If that didn't hurt your hand, you are no sissy, sir.
    Then again, that ain't no sissy saw.
    I'd sure like to see how it turns out after you do the repair, if you don't mind.
    Thanks for sharing. I've been there myself, I
    only have 1 saw that has a decomp, and it's my smallest saw! My bigger ones are older, before the decomps were so common, so I've racked my knuckles more than once.
    Usually when I do it there's at least 2 people watching,:Dnever fails.
    $ooline likes this.
  14. GrJfer
    GrJfer
    The Woods of Arkansas
    Chicks dig scars.
    $ooline, cnice_37 and fox9988 like this.
  15. clemsonfor
    As pointed out on the chainsaw forum truths thread (CSFT) ...only sissies use the Docomp valve (not sure of the wording or number):)
    $ooline, Evanrude and RJames like this.
  16. Hedgerow
    Hedgerow
    SW Missouri
    The extra comp makes em a little more sporty to pull over, but the timing advance is what "bites" ya..
    BAM!!
    $ooline, cgraham1, mdavlee and 4 others like this.
  17. Chvymn99
    Call me any name you want too...:p.... But just don't call me late to dinner...:p......:rofl: :lol:
  18. DexterDay
    My MM 460 is impossible to start without decomp.. At least by my little, short, fat self.... :) That is my only saw I MUST use it on. The Solo 681 has a plugged decomp. But it's not as bad.
    Glad your hand is o.k... Nice 440 :dex:
    Evanrude, Chvymn99 and clemsonfor like this.
  19. cgraham1
    cgraham1
    Nor Cal
    No problems here with my Mastermind 064 or 7900... but my 288 with the base gasket delete is a different story. Checked compression the other day and it's reading 183 psi. on my gauge. o_O
    mdavlee and clemsonfor like this.
  20. Evanrude
    Evanrude
    Byron, MI
    No complaining here, Clint. Just gotta learn to use decomp so it doesn't bite back. :saw:
    This saw just 1.5 tanks after port work. This has a used 046 D cylinder and new Meteor piston. I'm at 900' above sea level. My MMWS 260 pulls 205psi.
