This can't be gooder
Discussion in 'Modern EPA Stoves and Fireplaces' started by papadave, Jan 9, 2015.
  1. papadave
    So, after doing the overnight load a few minutes ago, I glanced over to the stove to see if the air needed to be adjusted, and this is what I saw........
    If you can get past the flash, notice anything amiss?
    The front tube screw stripped the first time I took it out to clean the pipes, and hasn't been real solid since. Tried putting in a slightly larger screw, but it wasn't, so that didn't work.
    Anyway, with the welders gloves on, I dang near burned my finger grabbing the tube, and pliers aren't going to work, so it looks like it'll have to stay that way until morning.
    I must have hit the tube putting in the last couple fillers at the top and not noticed.
    Funny though, it's still burning quite well, and secondaries look pretty normal.
    Stinny, milleo, jdonna and 3 others like this.
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    Looks like it needs a little TLC Dave. What are your plans to keep that in place?
  3. concretegrazer
    concretegrazer
    Southwest MO
    :bug: no good! Just don't throw it out with the ashes.
  4. papadave
    Not quite sure yet.
    Hard to work on it when it's toasty like that.:D
    I'll probably look for a larger self tapping screw in the morning.
    Still some jets of flame coming from the holes in that tube, but they're kind of lazy and pointing toward the top instead of forward/down.
  5. wildwest
  6. jdonna
    jdonna
    MN
    Maybe put a heli-coil and a stainless 1/4-20 bolt or some stainless strapping if the self tapper doesn't do it? Never a good feeling with a half broke stove and a box full of wood!
  7. Well Seasoned
    It never ends right....... good luck with that. Stripped screws can be a pita!
  8. Fanatical1
    Fanatical1
    You'll get it fixed up.... :yes: It's all about finding just the right screw/threads. Always can tap it out in the spring if needed..
  9. chris
    Screws should be stainless steel even a straight steel pin will work that can be inserted in the screw hole- slip fit as it does not need to be torqued tight. now if you broke the screw off so that the hole is plugged that is going to be a bit of work, as you need to get the residual piece out. One of those left handed drill type screw extractors might work. it is a pretty small screw in dia. some care must be taken.
  10. milleo
    milleo
    That's a bumma....Here's hoping you can fix it once and get it gooder again...:)
  11. Certified106
    Certified106
    In The Hills
    Just retap for the next size larger screw.
    Shouldn't take to long to fix that up but my guess is that tube being out is going to affect how the stove burned last night.
  12. papadave
    Well, gooder news.
    I got the tube reinserted this morning, with a new screw.......wow, that just sounds all kindsa' wrong.....and the stove didn't melt or anything overnight.
    I put in yet another 3/4" selftapper and it's loose yet grabbed just as the head hit the bracket. It will hold until spring or whenever I can let the stove go cold enough to fix.
    Knowing me, I'll put on one of those suits that are used to go down into volcanoes and have at it.......or not, and just do it.:eek::rofl: :lol:
  13. Fanatical1
    Fanatical1
    Did the stove have a smoke afterwords... :smoke::rofl: :lol:
  14. My IS heats my home
    My IS heats my home
    Albany, NH
    Nothing like gooder news in the morning. She'll be limping across the finish line this April
  15. papadave
    Had to run uptown for a couple water shutoffs, so I got a couple different types of screws to try while there.
    They look slightly larger.
  16. Loon
    Loon
    North of the border
  17. Woody Stover
    Woody Stover
    Southern IN
    Ah, that's a shame, but look on the bright side; Now you've got an excuse to buy an IS. :popcorn:
    BrianK, Chvymn99, papadave and 2 others like this.
  18. Sunfish
    Sunfish
    Success Mo
    Maybe need a gooder stove? ;)
  19. Backwoods Savage
    Nothing real serious there Dave but I can imagine what you were like when you noticed it. Not a good feeling at all.
    Certified106 and papadave like this.
  20. Stinny
    Twas a bumma wunt it milleo ... ayuh.
    fishingpol, milleo and papadave like this.
