  1. thewoodlands
    thewoodlands
    We hit -17 with it expected to drop even more, this is still warmer than last year.
    Just burning down the Beech coals so I should be loading up around 10:30 with more Beech.
    9pm10pm11pmThu
    12am1am2am3am4am
    9pm10pm11pm12am1am2am3am4am
    Forecast
    Cloudy
    Mostly Cloudy
    Mostly Cloudy
    Mostly Cloudy
    Flurries
    Mostly Cloudy
    Mostly Cloudy
    Flurries
    Temp (°F)-14°-16°-18°-20°-20°-20°-19°-17°
    RealFeel®-43°-45°-48°-49°-55°-55°-49°-38°
    Humidity63%60%60%61%61%62%64%65%
    Gasifier, Sam, bearverine and 3 others like this.
  2. greendohn
    greendohn
    S.E. Indiana/Rush County
    The schoolhouse has already called it off,,1 degrees a while ago and who knows what the wind chill is,,,pharking cold!! that's what I know,,snot was freezing to me 'stache when I was out of doors earlier,,
    Loon, Sam and bearverine like this.
  3. rdust
    rdust
    SE, Michigan
    I gave up on trying to heat my living room, it's on the west side of the house with 3 outside walls and terrible insulation. As long as it's in the teens I can leave the french doors open but when it's single digits for the highs it gets tough to keep the place warm. Closing the doors knocks roughly 300 sq' off a little less than 2K.
    Gasifier, Loon, Sam and 3 others like this.
  4. greendohn
    greendohn
    I packed the owb like a sardine can earlier with the red oak, ash and hedge,,it'll hold 'til mid-morning,,"set temp" is 180 degrees!
    Packed the garage stove with the same,,
  5. thewoodlands
    thewoodlands
    We hit - 20, just loaded up the Liberty with Beech and Sugar Maple and the pellet stove is running in the opposite corner.
    The basement is still 80, the living room is holding at 70 and the sleeper dropped a degree to 67 when I was burning down the Beech coals.
    sherwood, Gasifier, Loon and 3 others like this.
  6. rdust
    rdust
    SE, Michigan
    That's cold! What is it with the wind chill?
    Sam likes this.
  7. HDRock
    :shiver::shiver:
    We are at 3 now ,75 in stove room 72 at other end of house , burning a mix ash ,oak and sugar maple.
    Supposed to be 31 Sunday:dex:
    thewoodlands, papadave, Loon and 2 others like this.
  8. bearverine
    bearverine
    Winchester, Indiana
    Brrrr.. Minus five here. Wind chill supposed to be around minus twenty. Mid 70s in the upstairs l.r. (where the insert is.) Down in the low 60s in the b.r. just the way I like it. Slab wood and elm in the princess.
    I was having fun coming home tonight. It was cold enough that if I ran the heater on high, the engine couldn't maintain full operating temp. Now that's cold!
    sherwood, HDRock, Loon and 2 others like this.
  9. thistle
    thistle
    Polk/Guthrie Counties,IA
    -7 now,windchill -24.Supposed to bottom out at 10 or 12 below zero sometime between 3 & 5 AM,then slowly rise until tomorrow afternoon to around 20 above.
    1 big round shagbark,1 medium mulberry split,1 medium bur oak round for the night.Should still be a few handfuls of coals at 5 when I wake up. 74 in here now,will drop down to 68-70.
  10. Sam
    Sam
    Southern Minnesota
    Just got done loading and charring over both stoves with loads of elm and an older oak split way in the back of the Answer for good measure. They're both shutdown and set for an extended burn. I'll be back up in 5 hours to check and top them off. I like to leave the Answer set a little more open after my early morning loading that way it helps burn the coals down and it's warmer when the rest of the house wakes up. The wind all but died but it's a crispy -11f out right now with 76 showing in the basement and 71 in the living room. I came in after feeding a bale and remarked to swmbo that it didn't feel that horrible outside. She thought I was nuts but it really wasn't, without the wind trying to blow in/down every crack and crevice of a guys clothing!
    sherwood, HDRock and Loon like this.
  11. Loon
    Loon
    North of the border
    -14f and the dogs woke me up barking at the cracking house.:whistle: Topped off the T5 with ironwood rounds.:yes:
  12. ailanthus
    ailanthus
    Shenandoah Valley, VA
    2am reload. 65 in the stove room. When I get back to sleep, I'll be dreaming of a BK Ashford.
    HDRock, papadave, Chvymn99 and 2 others like this.
  13. Certified106
    Certified106
    In The Hills
    -8 outside now and the wind is still blowing. House dropped from 74 to 70-68 overnight and I am stuffing red oak and in the stove.
    HDRock, Sam, Gasifier and 1 other person like this.
  14. rottiman
    Current Conditions
    Current Conditions
    Cloudy
    -16°F
    Observed at:
    CFB Petawawa
    Date:
    5:01 AM EST Thursday 8 January 2015
    Wind:
    SE 7 mph
    Wind Chill:
    -32
    Conditions details
    Observed at:
    CFB Petawawa
    Date:
    Condition:
    Cloudy
    Pressure:
    30.2 inches
    Tendency:
    falling
    Visibility:
    2 miles
    Temperature:
    -15.5°F
    Dewpoint:
    -23.1°F
    Humidity:
    68%
    Wind:
    SE 7 mph
    Wind Chill:
    -32
    Forecast
    Forecast
    Graphic forecast
    Thu 8 Jan
    60%
    14°F
    Fri
    9 Jan
    14°F
    7°F
    Sat
    10 Jan
    40%
    10°F
    -13°F
    Sun
    11 Jan
    40%
    19°F
    7°F
    Mon
    12 Jan
    10°F
    5°F
    Tue
    13 Jan
    12°F
    -15°F
    Wed
    14 Jan
    40%
    16°F
    -2°F
    Detailed forecast
    Issued: 5:00 AM EST Thursday 8 January 2015
    and alas............woke up to frozen pipes and no water. Gonna be a good day.......................
    HDRock, Sam and Gasifier like this.
  15. Chvymn99
    3 degrees... Loaded up with Mulberry, Oak, & Hedge... Gonna have to run me around 13 hrs today. But its suppose to get up to around 20 degrees today.
    HDRock likes this.
  16. Gasifier
    It is -15 on the back porch this morning. They say a real feel of -30 from the wind. Ash cooking in the boiler. The system did well last night. 7-1/2 hours and still a real thick 7-8" bed of bright red coals when I reloaded while it was running. Most schools are delayed two hours. I think they will have a hard time starting the buses. They are outside in the wind.
    HDRock, Sam and Certified106 like this.
  17. fuelrod
    fuelrod
    Western Maine
    I'm showin -15.1, deffinetly "exercising" the boiler. Still a comfy 76 deg inside.
    HDRock, Gasifier, Sam and 2 others like this.
  18. Loon
    Loon
    North of the border
    Didnt get back on the pute after the reload as the ironwood had me in the 'Danger Zone' for 10 minutes and i was kinda busy dealing with it. :wacky:Even with it shut down completly....
    Note to self... Do not lay dry dry ironwood on a 3/4 full stove.
  19. sherwood
    sherwood
    Rottiman, Really sorry about the pipes. That's a bummer. Hope they are OK. Our low was early this morning. I see it was a record for this day.
    Our low was at 4-5 AM, -19 F actual temp, 100% humidity. Loon, the dog woke me then. He was barking on and off all night at the unusual noises. However, at 5 the barking became sustained and a bit urgent. -19, 100 % humidity out. He just knew something wasn't right with the world. It was cold! We were out for a few minutes. Snowing too. Humidity at 100 % for three hours, down to 86% now, with significant drop in the windchill. Doesn't look like a nice week coming up. For that matter, we are forecast to be 10 to 15 degrees below normal highs and lows much of the coming month.
    rottiman and Loon like this.
  20. Certified106
    Certified106
    In The Hills
    Ughhh that stinks...... Good luck hopefully they aren't busted.
    rottiman and Sam like this.
