Hanging signs on a block wall?
Discussion in 'The DIY Room' started by DexterDay, Nov 20, 2013.
  1. DexterDay
    It's exactly what the title suggests? I have a bunch of signs that I want to hang on my basement/block wall? What's the best way.
    I could drill into the mortar lines and use small nails? I thought that may be best. The wife suggested Liquid nails :confused:. I told her that was a great idea, but... No.
    I have more signs coming. . And a bunch of Nascar License plates that I want to hang.
    Thanks for any help in advance. :)
    fox9988 and BrowningBAR like this.
  2. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I'm interested in this also if there is a clean and easy way to do this. With these stone walls I can make a damm mess of chit pretty fast.
    I just bought a caulking tube of heavy duty liquid nails that I am trying out on a plastered stone wall in the attic. I will be testing that on Friday.
    DexterDay likes this.
  3. smoke show
    smoke show
    Pittsfield, Wi
  4. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Will it stick to mortar and stone? How strong is it and could it hold a hook for frames?
  5. HDRock
    The 3M Command Adhesive Products I think would work for your painted cinder block.
    There is a lot of options for types of hooks
    When you are ready to take down or move what you hang up , they come off cleanly - no nail holes, cracked plaster or sticky residue
    FAQs
  6. stuckinthemuck
    stuckinthemuck
    Looks like all of the stuff you want to hang is light.. So adhesives or double sided tape should work. If you wanted to hang something heavier, i'd drill into the block with a masonry bit, pound a wooden dowel into the hole, saw it off flush with the wall and then pound a nail into the middle of the dowel. Would require some accurate measurement beforehand to ensure that you're drilling in the right place. Additionally, if you drill through the block wall, you'd need some construction adhesive to keep the dowel from pushing through.
  7. ironpony
    ironpony
    Mid Ohio
    You are loosing massive amount of heat thru the exposed block walls. My suggestion is to frame them in, insulate, hang drywall and finish, repaint and the use thumb tacks to secure your signs.
    sorry could not resist. 3M foam tape.
  8. clemsonfor
    Drill then put in masonry or plastic anchors and screw in them. I do kike the dowel idea though.
  9. lukem
    There's special putty for hanging posters. I remember it from grade school. Our school had painted block walls and the teachers would use this putty (sticky tack?) to hang all the stuff on the walls. It is pretty stout stuff and I'm sure it would hold up metal signs if you are generous with the application.
    Don't drill those walls...
    DexterDay and smoke show like this.
  10. clemsonfor
    That stuff I think is called tacky?
  11. DexterDay
    If I drilled, it was gonna be 1/16" holes, about an 1/8"-3/16" deep and only into the mortar lines. I have some super small nails I just just gonna stick in them.
    Think I will try the 3M sticky tabs 1st. These signs are pretty thin and light.
    The 2 posters are going under the glass top of the bar. :) But the tacky stuff still might work for the smaller signs.
  12. eatonpcat
    Tapcon masonry screws...I believe they make them that cut their own threads now!
    thistle, the GOAT and basod like this.
  13. lukem
    Thumb tacks in the sill plate and hang them with fishing line?
  14. DexterDay
    May be onto something here?? Thank..
    Great thinking minds on here :)
  15. clemsonfor
    I had thought about the fishing line thing, or hanging them from the ceiling like old school picture moulding but did not mention it cause I thought you might think it was ghetto!
    eatonpcat likes this.
  16. Woodwidow
    I think the sticky stuff is called Blue Tack. It looks like chewing gum but works quite well especially for posters.
    campinspecter likes this.
  17. basod
    basod
    Mount Cheaha AL
    Hung a bunch of stuff(heavy plaques, posters, frames etc) at work after we had the building repainted this summer with the 3m command Velcro strips they have held up fine on drywall - not sure on cinder block. Just be sure to clean both surfaces with denatured alcohol -bulk sized medium duty strips are available online for reasonable money.
    Anything really heavy I'd use some tapcons
  18. the GOAT
    the GOAT Banned
    +1
    Tapcons and be done with it. If the tapcon doesn't bite nice and tight cut an inch or so off a plastic wire tie and put that in the hole then the tapcon -- nice and tight and you don't have to worry about it failing.
    thistle and clemsonfor like this.
  19. clemsonfor
    Concrete nail gun, duct tape. Chewing gum. Bailing wire. Whatever.
  20. clemsonfor
    Sweet kitty in the picture.
