new member needs some help...
Discussion in 'The Pellet Bag' started by Scotty Overkill, Jan 5, 2015.
  1. Scotty Overkill
    Guys, welcome jerseygirl! She's new to the club, and she's learning to navigate the forums, so I pointed her in the right direction. She's looking for a good, dependable pellet to burn because she's not real happy with the ones she's using now. I know I'm leaving her in good hands with you guys. She'll take it from here. She should be along soon.
  2. wildwest
    Hi jerseygirl , I am new to pellet stoves too and SOOO appreciate the opinions advice I was/still given here! No doubt you will like here :) PS I am a girl too.
  3. IHATEPROPANE
    IHATEPROPANE
    We would need to know what pellets are available in her area.
    will711 and jtakeman like this.
  4. jtakeman
  5. eatonpcat
    Welcome Jersey Girl.
  6. jerseygirl
    jerseygirl
    New Jersey
    Good morning, and thank you for your guidance...I found That I can pick up at Bucks pellets and their available stock as listed on their website are by the ton, Forest Pride& Okanagan Gold. By the bag Okanagan Gold, Forest Pride and Sry Creek. I am currently burning Easy Heat and not to happy with amount of 'clinkers" and not much heat. Are softwood pellets ok?
    fox9988 likes this.
  7. IHATEPROPANE
    IHATEPROPANE
    Softwood is definitely OK. There will be some others coming by that have burned those exact pellets and can give you some guidance. My suggestion would be buy a couple of bags of each and see what works best for you.
    Scotty Overkill likes this.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    I'm sorry, I would have mentioned Buck's but didn't think you were anywhere near them. Joe is a really good guy, he'll take care of you. The softwoods are ok but like IHP said, try a few bags of different kinds to see what your stove likes. Those Forest's Pride pellets, I would think, would burn good for you though.
    will711 likes this.
  9. jerseygirl
    jerseygirl
    New Jersey
    Ok, I will try them.
  10. Well Seasoned
  11. jerseygirl
    jerseygirl
    New Jersey
    Have you heard bad or good about Vulcan pellets?
  12. Stinny
    Welcome to FHC jerseygirl ... Vulcan pellets... hmmmmm ... maybe Spock knows sumthin about em... :yes:... ;)
    Sorry, couldn't resist. I don't have a pellet stove, but lots of folks here do.
    Spock, will711 and eatonpcat like this.
  13. slvrblkk
    slvrblkk
    Northampton, PA
    I've never burned them but I believe they typically weren't that great. Hopefully someone else will chime in on them.
  14. Birddog91
    Birddog91
    Lakes Region NH/Connecticut
    Welcome JG. I am primary burner of softwoods. Blazers and Vermont's are my two brands. But since joining these pigs, I have taken their advice. Like IHP states get a mix of them, at least 2 bags each if possible to get the real story. I found that I like minuteman now which is a cheaper option. And I have my first two bags of a lower end hardwood going in the hopper as we speak. I have a ST Croix and like mentioned your results may vary!! Happy hunting!! And let us know your results!!
    jerseygirl and IHATEPROPANE like this.
  15. Birddog91
    Birddog91
    jerseygirl likes this.
  16. will711
    will711
    Pocono Mts.
    Welcome to the Show Jgirl .
    What stove do you have?
    Have you checked out Lowe's or Home D, to see what they have in stock?
    IHATEPROPANE likes this.
  17. Skier76
    Skier76
    CT and SoVT
    Welcome!
    I burned a few bags of easy heats in my stove. My stove eats pretty much anything without complaining. However, I noticed the heat output wa so so with the easy heats. They make a decent shoulder pellet.
  18. smoke show
    smoke show
    Pittsfield, Wi
    Welcome aboard! Vulcan pellets have a bad reputation in this neck of the woods. Good luck!
  19. Spock
    Spock
    MA
    Welcome jerseygirl ! Never seen Vulcan pellets in my area. Would have to try them if I did! What pellet stove do you have?
  20. Lousyweather
    Lousyweather
    J-girl.....you're sure to find help here, and likely also to get just as many opinions on what's good and what isn't. As mentioned above, buy several bags of each kind, try them out, and come to your own conclusions. Everyone's stove and install is different, as well as their domicile, needs, local retail conditions, and climate. Down there in sunny, tropical Joizey, I'm sure you'll find some great options!
    Welcome to the forums!
    jerseygirl and will711 like this.
