poulan 306a
Discussion in 'Chainsaws and Power Equipment' started by markr, Jan 2, 2015.
  1. markr
    markr
    ohio
    Got my usedpoulan 306a today. 120 psi runs with gas in carb. (Lines maybe carb rebuild etc.) No bar or chain. Got it as a back up and I like these old saws. Suggestions on bar and chain. 20 inch? What say you?
    Chestnut likes this.
  2. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    I have a number of 306 saws, at 59 cc's they will pull a 20" bar.
    HoneyFuzz and raybonz like this.
  3. DexterDay
    Friendly bump..
    I hope someone has the info you need.
  4. Mag Craft
    I have a 306a and yes it will pull a 20" bar just fine. Also like you mentioned if it will start on prime but not run then I would do the fuel line, filter, and kit the carb. Like Guido mentioned 59cc and not a bad running saw.
    Just make sure that you are aware of it being an older saw and keep your ear tuned to the engine in case a crank seal is going bad.
    DexterDay likes this.
