Welding tables and welders show em off thread !
Discussion in 'The DIY Room' started by Pallet Pete, Nov 8, 2013.
  1. prell 73
    prell 73
    ia
    Well maybe u give a few pointers I can tig with this setup but not to good at it . I to can mig and stick very well I've been doin it for 20yrs.
  2. Elderthewelder
    Elderthewelder
    Washington State
  3. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    I missed this post earlier. When I worked for a welder all the in house fabrication for the most part was done with a high powered Mig and that was my job. Most of the stick welding was done in the field where we did above ground fuel systems etc. and on those jobs I was mainly there to tighten down bolts and lift heavy stuff. I did love the oxy/ace torch that we strapped to the pipe though, so pretty as it ran around and cut it. Then I had to grind all the slag off lol.
    Yeah, I was his slave but I learned a lot and loved that job, it just didn't give enough hours.
    Stinny likes this.
  4. Elderthewelder
    Elderthewelder
    Washington State
    a little aluminum tig work on some 1/2 inch plate
  5. eatonpcat
    That's a beautiful weld on aluminum!!
  6. prell 73
    prell 73
    ia
    Very nice welds bud
  7. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Stinny likes this.
  8. Gasifier
    I tried welding once. :picard:Should I not have done that?
    Pallet Pete, Stinny and prell 73 like this.
  9. HuskyFan
    HuskyFan
    ann arbor
    Whats an easy way for a guy to learn to tig weld? I can mig and stick but never have tig. I want to weld some alum.
    WeldrDave and Stinny like this.
  10. Stinny
    WeldrDave is just one of the experienced welders here HF. There are others as well. Bet they'll be along.
  11. Elderthewelder
    Elderthewelder
    Washington State
    like anything else practice,practice, practice. Do you have a tig machine or access to one? or know someone who can teach you?
    Aluminum tig is not that difficult once you get the hang of it
    Watch some of the videos on this site they are very informative
    http://www.weldingtipsandtricks.com/index.html
    WeldrDave likes this.
  12. WeldrDave
    Like elderthewelder said, practice!!!!!!!!!! When you TIG weld, things change on every different thing/material you weld. Such as this; ... When you weld aluminum you need a machine that has the capability of high frequency "continuious" and when your welding Stainless or mild steels, you "don't nesseserally" need HF but it's nice to have for a "start" arc. Next is changing your polarities.... AC to DC- etc... cleaning.... Tungsten.... ball or point.... Gas mix, Argon, CO2, mixed gases, so there is a lot to consider here and how much do you want to spend on a machine, regulators, gases etc... For the first line in your question I suggest this.... Go to a vocational school or a night class, that will get you started. :)
