class a double wall insulated pipe temps
Discussion in 'Modern EPA Stoves and Fireplaces' started by shaggy wood dump hoarder, Dec 23, 2014.
  1. shaggy wood dump hoarder
    menomonie
    Hey guys I'm trying to put a barrel kit stove in my garage. I got 4sections of 8 inch pipe that will take me most of the way out, and 6inch up to that. I'm going through my ceiling that is osb and was wondering if any of you have a similar situation and knew what the pipe temps on the outside of the double wall insulated got to be. My 6 inch on my boiler and when it's running the pipe is as cold as it is outside. Also if anyone knows any other regulations on it it would be a great help! Thanks!
    wildwest and Pallet Pete like this.
  2. haveissues
    haveissues
    Hudson Valley
    usually 2" clearance for class A but I would check the manufacturers website. They should all have tech sheets posted. Remember, just because it is only warm to the touch under normal circumstances doesn't mean it will be that way should you have a chimney fire.
  3. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Hello and welcome aboard I'm gonna move this to the stove section for ya! ;)
  4. Pallet Pete
    Ovid
    And now the reply lol..
    Again welcome to FHC!
    First a few questions?
    Do you have a through the roof thimble kit! That is a biggy...
    Second have you looked at insurance? Garage installs are not accepted most places and almost all insurance will drop you in a heartbeat if they find out your using a barrel stove....
  5. Backwoods Savage
    Welcome to the forum shaggy wood dump hoarder.
    Most of the insulated chimneys will be warm to the touch and right on the verge of being too warm to hold onto very long.
    I think you might have some problems going from 6" to 8" because that will reduce your draft tremendously. Also, Pete is correct about wood stoves in garages. It could cause some problems should anything ever happen. Yet, we know of many who have stoves in garages. What is right?
  6. greendohn
    greendohn
    S.E. Indiana/Rush County
    Why are going 6" to 8" ?
    You HAVE to have the THIMBLE/INSULATION BOX when going thru a wall/ceiling, there are no shortcuts or way around it to meet code around here. These deals are basically what give you zero clearance to combustibles.
    You can usually buy these at Menards or Rural King. The insulated pipe I bought has a 3/4 inch clearance to combustibles.
    NO SHORTCUTS on installing a stove or the flue pipe,,,pay attention to all of your clearances with the stove and your pipe.
  7. shaggy wood dump hoarder
    menomonie
    Thanks guys! I do not have the thimble yet but was planning on putting a decent gap around the whole hole either way. Reason for 6to 8inch is I got the 8inch pretty cheap of craigslist. I only plan on burning when I'm thing to be on the shop all day and burning only dry dry wood so I'm not worried about a chimney fire.
  8. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    This is more true than the values that Jesus has taught us. They don't like it because people store gasoline etc. in the garage, and they don't care if you don't either. Just a code thing.
  9. oldspark
    oldspark
    NW Iowa
    Best to call your insurance company, mine had no problem with it what so ever.
    Just follow the specs. of the maker of the pipe and you should be good to go.
    The draft may be just fine going from 6 to 8 inch, some times you never know until you try.
    greendohn likes this.
  10. shaggy wood dump hoarder
    menomonie
    Funny thing though I'll only be out there heating with the stove when I'm welding I have a pile of projects to do with the welder and would like to keep it warm. As I found on another post one day, the molten metal flying everywhere around my shop along with sparks and what have you is probably more concerning than a fire inside a steel box entirely contained in itself lol. Just a pain in everyone's a**if you ask me. Only takes a few to ruin it
  11. My IS heats my home
    My IS heats my home
    Albany, NH
    shaggy wood dump hoarder , is your garage attached or unattached to your home?
    The guys have all been correct in saying the Ins co will not cover your garage with a
    woodstove in it, especially without an inspection from the towns building inspector
    for a safe install including a permit. Is your garage a place of business? I know your
    trying to keep yourself warm while you work on the cheap but you may be putting
    yourself in harms way.
  12. shaggy wood dump hoarder
    menomonie
    It's unattached. And no not really a business just some under the table work once in a while and stuff for family and friends and my 5x10 trailer for hauling wood.
  13. oldspark
    oldspark
    NW Iowa
    Once again CALL your insurance company, mine had no problem as long as the stove had a UL tag on it (no home made stoves). :headbang:
  14. oldspark
    oldspark
    NW Iowa
    Very good point but some insurance companies have issues with welding depending on how the shop is built.
  15. oldspark
    oldspark
    NW Iowa
    My insurance company is a "local" company so a good chance you will have better luck then dealing with a bigger company.
    Brain cells seem to be much more intact here then other parts of the country.:)
  16. shaggy wood dump hoarder
    menomonie
    They really had no problem huh? I meant to call this week but got caught up with New year's and getting my trim up into my old bed room turned wood shop for cutting sanding jointing and routing and staining. Let the long process begin!
  17. oldspark
    oldspark
    NW Iowa
    Not a bit as long as the stove was not home made, they even sent me a paper with all the stove clearances needed.
  18. TurboDiesel
    State Farm gave me a tri-fold pamphlet when I asked about a woodstove. It had clearances and some other info about combustible materials. If i can find it i will put some info up here.
  19. shaggy wood dump hoarder
    menomonie
    Thanks guys. There is hope after all!
