Benefits of upgrading old wood furnace
Discussion in 'Modern EPA Stoves and Fireplaces' started by dgeesaman, Dec 21, 2014.
  1. dgeesaman
    dgeesaman
    Elizabethtown, PA
    My home is 1500 sq ft and has a wood furnace by Oneida Royal that is thermostatically controlled and tied in to the vents. It's around 25 years old. It seems to have limited control over the burn and will not last the night.
    Aside from lower emissions test results, what are the benefits on installing a newer wood furnace? Do they make the wood last longer / get more heat out of it?
    Should I get a catalyst stove or try to get a non-catalyst stove before they're gone?
    Or should I go with a gasification burner instead?
    Dave
    Stinny likes this.
  2. jeff_t
    jeff_t
    SE MI
    Are you looking for a stove or furnace?
    Not many catalytic furnaces out there. Blaze King Apex is the only one that comes to mind.
    There are quite a few non-catalytic EPA furnaces. Drolet Tundra is one of the more economical choices. Huge thread at AS about it.
    A new, EPA furnace should definitely save you some wood.
    dgeesaman likes this.
  3. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Furnace. It's a wood furnace that uses the vent system used by the electric heat pump and central air. We have the thermostats set to keep the electric heat off.
    I've also been looking at gasification boilers - which still heat the air for heating, but I guess they circulate water. They are also much larger and more expensive. My little furnace room is well sized for what is there, but won't handle something twice the size.
  4. Sam
    Sam
    Southern Minnesota
    I second the Drolet Tundra. At least once a week I go over to the website and drool over replacing my Daka with it. The Daka works as a heat source but burn control is totally lacking and there's no secondary burn provisions at all. Combined with the fact that the door is way to high on the firebox resulting in smoke spillage (even with a decent draft and the flapper installed on the top of the opening) and it's excessive appetite for wood and it leaves me wanting.
    Huntindog1 and dgeesaman like this.
  5. Backwoods Savage
    Dave, a 1500 sq ft home should not require a lot of heat. Ours is near that size and we burn 2 1/2-4 cord of wood per year. It was last year we burned the 4 cord. Before that, 3 cord is about all we burn.
    We hesitated on the cat stove before buying as we'd heard some bad stories. Long story short, we went for the cat stove, a soapstone stove from Woodstock. We could not be happier. Before this stove we burned 6 cord per winter and one winter burned 7 1/2 cord. In addition, we closed off part of the house and was still cold. When we installed the Fireview, we still wasn't quite sure because it is a smaller stove than we had before. But, we've never had to close off part of the house and we keep it 80 in here all winter long. In addition to that, we have increased the size of the house and there is no problem still heating it with the Fireview.
    Most of the catalysts are good now but it was not always that way. They keep getting better and better. Sure, you have to change them off and on but it is no big deal; just normal maintenance. But furnaces can be nice and also the gasifiers.
  6. Huntindog1
    Huntindog1
    South Central Indiana
    yes going to a free standing stove would heat that house easy and use alot less wood.
    Have you checked out the thread on here about the Ideal Steel Wood Stove.
  7. bogydave
    For stove, the catalytic s are the most efficient .
    Burn less wood & longer burn times .
    The new furnaces & gasifiers are efficient too.
    They all need to be feed wood daily.
    Will it be the only source of heat ?
    I have NG furnace so we miss a day or two with out worrying about things freezing up.
  8. dgeesaman
    dgeesaman
    Elizabethtown, PA
    I wasn't being careful used the word stove. I'm only considering furnaces.
    We have an electric heat pump and emergency direct heaters. Last winter we had just moved in and had not yet gotten the wood furnace inspected and prepared. Our electric bills were horrific. This year we're using the wood furnace nearly 100% of the time.
    We are currently feeding it a couple logs every several hours. I adjusted down the air inlet control a few chain links last night since it seemed to burn too fast. Overall we're not using more than 8 pieces of wood a day but the burns are short and lots of attention. A 8h burn would be fabulous. Our wood is decent stuff too.
    I should probably always feed it a full load of wood to get a really long burn but I'm cautious about it burning too fast and overheating. It's not a big fire box - long but not wide or tall. But nearly full sized burns don't go much slower than small ones.
  9. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Hm under $2k. That's better than I expected.
    David
  10. JA600L
    JA600L
    Lancaster, Pa
    You might also want to check out DS Machine furnaces. They are made here in Lancaster PA.
  11. Sam
    Sam
    Southern Minnesota
    Wow, they have a really high efficiency claimed. I'm curious though as to how they advertise fully automatic control yet have 4 manual rotary air control knobs on the front. Maybe they're just for decoration or it's an old "stock" photo?
  12. JA600L
    JA600L
    Lancaster, Pa
    I think it's for decoration. These stoves are primarily built by Amish for Amish, however plenty of their models take electric hookup.
  13. rottiman
    When I first bought my house, there was a Summeraire Wood-only furnace in it. The first winter we were here @ Xmas it was -25 and howling snow. We were going away to friends for the day, so on a bed of good red coals, I loaded the furnace full of 3 year seasoned red oak as we were to be away until that night. All was well, the fire was good.............and then with the wind howling, the power went off.
    Within 5 minutes the steel was beginning to overheat in the furnace. I peeled the cabinet skin off of it and then decided to put it down with some water as it was realty starting to over fire. Well, it was like the birthday candle that kept re-igniting. Next problem was that I was out of water as we are on a well and without hydro, no well pump-no water. Next move was to start trucking snow in to throw on it. About that time the hydro came back on. Had it been another 15 minutes, we would have been gone and no doubt came home to the ashes of what would of been our home. Needless to say the wood furnace was replaced with 2 air-tight stoves and I never looked back. You couldn't pay me enough $$$$ to ever have another wood furnace. I'll keep and enjoy my stoves, thanks......................
    Huntindog1 likes this.
  14. JA600L
    JA600L
    Lancaster, Pa
    Wow, I never thought about that happening before. Do modern furnaces have a safety feature to prevent overheating when the power goes out? How do they default?
  15. Steven Humes
    Steven Humes
    Holt, Michigan
    I have a daka 521 fb, a 1100sq foot house. My furnace has a dial that you dont go over there is no power. Also i never go over that anyways because my house is small. The dampener closes when is get hot. Also know what your burning. I like my furnace. The dial is below the door cant go over the second line when you have no power. I have also had an incert, wife wanted a bigger wood burner so it could go all night. The one room we had stayed warm but that was it. We had an open floor plan too. Floors were cold so we got the 521fb. Put the 521fb in the basment, burns longer and keep whole house warm no matter the temp out side. I dont know everything about wood burners but i can say i like my wood furnace over a woodstove.
    Sam likes this.
  16. prell 73
    prell 73
    ia
    Daka's are awsome that's what I'm puttin I my house.
  17. Steven Humes
    Steven Humes
    Holt, Michigan
    If you got the cash make sure you get the twin blowers on the daka, it came with one 550cfm, could use another. But i have the blower on the main unit help push the air. Works great 16 out side 75 inside only coals left in it. Love the daka 521fb the second blower help push the air out of the duck work if your ducks are hot then the hot air is in them not you house.
  18. prell 73
    prell 73
    ia
    I plan on using my furnace fan to
  19. Steven Humes
    Steven Humes
    Holt, Michigan
    I am new to this forum but i like it alot so far if you have any question let me know about the daka i can try to answer them. Looks like you have some sweet gear in your main pick. I dont have wood splitter that works right yet. What do you heat your house with now? Or barn i heat my garage with wood too.
  20. prell 73
    prell 73
    ia
    I'm goin to use my furnace fan to
