Unpleasant suprise today
Discussion in 'The Wood Pile' started by mike bayerl, Dec 14, 2014.
  1. mike bayerl
    mike bayerl
    I was out thinning some ugly trees in my woods today and got a very unpleasant surprise.
    Knarly barber chair.
    I knew it was leaning so I think I got too caught up in dealing with the lean. The tree had a very healthy crown and no external sign of rot that I could see. When I put my face cut in, a saw a little bit of rot in the center, but didn't pay enough attention to it. Started the bore cut and then I heard the dreaded crack and saw the crack going up out the corner of my eye. I was able to high tail it out of there and in the end, the tree was on the ground and I was perfectly unharmed. However, it was a very good reminder to pay attention and don't skip steps when felling trees.
    Drvn4wood, Gark, Deacon and 23 others like this.
  2. savemoney
    That easily could have been a very different outcome. Thankfully, someone was looking out for you. Trees are full of energy until they lay flat on the groung. Glad you are ok, and yes, always good to talk about those events as a reminder to yourself and a heads up to others.
  3. foragefarmer
    foragefarmer
    Central, Virginia
    Glad you are ok. That is a nasty looking tree.
  4. Certified106
    Certified106
    In The Hills
    Dropping trees is dangerous work! Things happen in a instant and can go bad so quickly that you don't have time to react. Really thankful that this ended well for you and you weren't hurt!
  5. mattjm1017
    mattjm1017
    Yikes:eek: glad you made it out ok and didnt get hurt that could have ended badly.
  6. Loon
    Loon
    North of the border
    That looks like a friggen mess mike.. Good ya got outta the way!:yes:
  7. Gasifier
  8. ailanthus
    ailanthus
    Shenandoah Valley, VA
    Agreed, that was a nasty one. So glad you were out of harms way.
  9. Joe
    Joe
    Mesick, MI
    Glad you're safe! Rotted trees are no joke.
  10. Well Seasoned
    You were certainly being watched over! Glad all went well, could've certaintly gone a different route.
  11. mike bayerl
    mike bayerl
    Thanks for all the support. The tree actually came down pretty slowly, in the "right" direction and didn't jump backwards or to the side, so I was way out of the way when it did finally fall. However, what shook me up was the "what if's" later. This is as close to as I ever want to be to "the bad one."
  12. 460magpro
    460magpro
    usa
    that is scary stuff right there glad you are ok
    Backwoods Savage and Shawn Curry like this.
  13. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    Glad you where safe. Hope the saw made it also.:saw:
  14. Loon
    Loon
    North of the border
    Bar mighta got pinched on the run out!:D
  15. mike bayerl
    mike bayerl
    I left the saw in the bore cut when I split. In the picture, the saw is right where I found it, unharmed and still idling.:yes: Better lucky than good sometimes.
  16. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    Great to hear. If it would of been me my old 290 would of been a boat anchor.:D
    jetjr and Shawn Curry like this.
  17. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Sometimes your good...sometimes your lucky..... and sometimes your both. Glad everyone is ok.
    Gark and Shawn Curry like this.
  18. GrJfer
    GrJfer
    The Woods of Arkansas
    Glad to see you could turn a bad situation into some firewood .
    Moparmyway and Shawn Curry like this.
  19. rottiman
    Scary for sure, glad you are okay. Good lesson to be learned for sure.
  20. Shawn Curry
    Shawn Curry
    Western NY
    Looks like someone tossed a grenade in there!! :eek: Glad you're ok! :yes: Live and learn!
