Felling, Bucking, The right way, Good Video
Discussion in 'The Wood Pile' started by HDRock, Nov 1, 2013.
  1. HDRock
  2. HDRock
  3. HDRock
  4. Dascro
    Dascro
    Southwest PA
    Good info. Very informative. Thanks.
    Dave
    Horkn and HDRock like this.
  5. HDRock
    Once you figure out how to navigate this site there is a lot of good information there
    Spend some time, Click around and see what you can find
    they have tests that you can take to see if you have learned anything
    here is some links but there's a lot of info there if you can find it
    https://www.osha.gov/SLTC/etools/logging/manual/felling/cuts/notches.html
    https://www.osha.gov/SLTC/etools/logging/manual/felling/cuts.html
    https://www.osha.gov/SLTC/etools/logging/index.html
    https://www.osha.gov/SLTC/etools/logging/manual/limbing_bucking.html
    https://www.osha.gov/SLTC/etools/logging/manual/limbing_bucking/examples.html#springpoles
  6. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    Thanks more to it than just letting the saw rip.:yes:
    Horkn, Upstatewoodcutter and HDRock like this.
  7. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    I prefer a simple back cut, then again I avoid anything with a major lean, I know my limits. :yes:
    bigbarf48 likes this.
  8. bearverine
    bearverine
    Winchester, Indiana
    Good stuff.
    HDRock likes this.
  9. GRIZ
    GRIZ
    Good video :yes:
    HDRock likes this.
  10. GRIZ
    GRIZ
    I love the bore cut:yes: and hinge The best way to cut any tree:thumbs:
    firecracker_77, Horkn and HDRock like this.
  11. boettg33
    boettg33
    Wakefield, RI
    Getting lucky is often one step away from death. This guy is a complete tool.
  12. boettg33
    boettg33
    Wakefield, RI
    When I started doing research on buying a chainsaw, I also researched how to fell trees. This is the one video I found to be the best. This was long before I found this site. Now that I have my saw, I've still not taken down any trees. Soon. However; this is the method I plan to follow.
    Jason from RI
    Horkn, HDRock and Upstatewoodcutter like this.
  13. HDRock
  14. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    Thanks for the refresher. Might be able to finally get out a fell some trees.
  15. Horkn
    Great bore cut demonstration, and the limb shaving is a new one for me.
    I still have yet to try a bore cut, even on heavy leaners.
    You can really do a lot of stupid stuff with a saw if you don't think ahead. Most stupid stuff can kill you, but not ensuring your escape plan, clearing to make it safe, and assessment of the tree BEFORE you cut are absolutely necessary and something I've always done.
    HDRock likes this.
  16. HDRock
    yeah also I have found that when limbing keeping the area clear is a lot more productive and safer
    Stinny and Horkn like this.
  17. Woodrat1276
    Woodrat1276
    Ky
    HDRock likes this.
  18. mr.finn
    mr.finn
    Mass
    Great informative video, thanks for sharing.
    Here is one I couldn't help sharing, Bob Villa chainsaw tips
    Stinny likes this.
  19. Stinny
    Like Bob says... "good luck with your project"... ya might need it droppin em' 90 degrees off the hinge notch... :picard:
  20. firecracker_77
    firecracker_77
    IL
    I haven't cut down a tree in almost 5 months. I am missing the thrill of watching one come down. The bore cut is the safest technique. You can check things out before the final bit of back cut takes it down. A back cut to the hinge offers the least amount of control.
