Mobile firewood storage
Discussion in 'The Wood Pile' started by Sam, Nov 6, 2014.
  1. Sam
    Sam
    Southern Minnesota
    Looks like a very similar size to mine. Do you stack them 2 high? How does your loader tractor handle them as far as the weight goes? Two years ago I switched from a 85hp loader tractor to a skidsteer. The skidsteer fits in my shop with a 9' door and it's much handier on our smaller acerage, in and out of the pole barn, etc.
    Jack Straw likes this.
  2. Sam
    Sam
    Southern Minnesota
    With the racks and the skidsteer I hope to stay in good enough shape to be able to burn wood the rest of my life. I realized a few months ago that I'm never going to be 20 again so I better start working a little smarter now! Now if someone just came up with a featherweight chainsaw...
    fuelrod likes this.
  3. Stinny
    Christmas is coming Shawn. If your Dad is like this dad with his back issues... he'd love a 30" pickeroon to pick up splits, etc. Those wooden handle picks seen here recently look really nice too. Just a thought... ;)
  4. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I haven't stacked them yet but I may in the future. I would like to get a carport to store them in. I have to be careful not to overfill the racks, they are a bit much for my tractor.
    Stinny likes this.
  5. Stinny
    I bet they're heavy when the wood is green. A great way to store and move them tho... :yes:
  6. Jack Straw
    Jack Straw
    I fill them up about 3/4 full, move them to their storage spot and then finish filling them up. They seem light enough after sitting for 2 years. Some how I had the fore sight to build them before I bought the tractor. :whistle:
    Gasifier and Stinny like this.
  7. Sam
    Sam
    Southern Minnesota
    I was thinking about stacking mine just to keep them in a more compact area but then I couldn't overfill the bottom ones. That lead me to the idea of looking for old pallet racking and stacking them that way. Maybe the bottom ones wouldn't get enough sun then? Or, and this is a distinct possibility, I'm just over-thinking it and I should just be happy with lining them side by side!
  8. Stinny
    How does that happen... jeeenyus... right there... :D
    Jack Straw and Sam like this.
  9. bogydave
    Hey
    We got your back here :) :campfire:
    Gasifier likes this.
  10. fuelrod
    fuelrod
    Western Maine
    I haven't lost one yet. I snug 'em up pretty good, and at 4-5 mph, things don't get too out of control. It does make a big difference with a SS. With the ridged frame and no suspension (movement) you usually have 2 opposing corners firmly planted on the ground, with the other 2 corners "light".
  11. JustWood
    JustWood Guest
    I cut a couple of old scrapped out 10' dump bodies in half. Weld the tail gate shut on the one half and it makes
    2 big buckets. Hold right about a cord. Mainly use them for shoulder season wood. Only need a cord in fall and one in spring . I like that I can stick one right by back door with no mess and when yur done wether empty or not it can disappear fast .
    Gasifier, swags and Shawn Curry like this.
  12. Freakingstang
    Freakingstang
    i used those metal crates from liquid storage totes. I can load up the trailer with 6-8 of them and load them on site and move them around when I get home with the tractor. No need to load, unload, stack, move to the house come fall, etc.. pick them up and take them to the back door. Its also easier to sort green/unseasoned wood with them.
    Chvymn99, Mitch Newton and Gasifier like this.
  13. swags
    swags Moderator
    I use racks like that too, I've tried a few different methods. First I made a three sides pallet, then used the totes like stang and also made a rack out of 1 pallet and a few 4' 2x4s. The racks with 2x4s look better IMO but the three sided pallet ones hold up better and hold splits in there a lot tighter. I'm now using the totes to store uglies in. They work perfect for that.
  14. Sam
    Sam
    Southern Minnesota
    I was thinking about using the totes too but I couldn't find them for less than $50 a piece. Any tips on places to look that might be just "disposing" of them?
  15. basod
    basod
    Mount Cheaha AL
    Check with a spray foam insulation contractor
    Chvymn99 and Sam like this.
  16. swags
    swags Moderator
    I can get them locally for $30-50 but if you look online they are over $100 here.
  17. Sam
    Sam
    Southern Minnesota
    Hmmm, that makes me think that it might be easier/economical to take one of these http://www.tractorsupply.com/en/store/feedlot-panel-cattle-16-ft-l-x-50-in-h and fold it into a box shape on top of a pallet? Looks like for a normal pallet there'd be about 16" of overlap or I could just custom build the pallet like I've been doing for some other projects using discarded 4x4's. Now I kinda wish I had explored that option earlier!
    Chvymn99, Mitch Newton and basod like this.
  18. Sam
    Sam
    Southern Minnesota
    Well, I finally got to unload one of my firewood carrying pallets into the add-on furnace room last night. I didn't have very far to carry it with the skid-loader but I hate going back to pick up pieces that jump off and there's a bit of a slope getting down to the walkout basement so I thought I'd try some recycling. Instead of cutting the net-wrap off our round bales of hay I've started to just unwrap it and save the netting. It took a little doing but I managed to net-wrap my firewood carrier and I didn't lose a single piece! As you can see from the pics I had it heaped up pretty high as well, pretty much at the angle of repose if you asked me!
    Backwoods Savage and Chvymn99 like this.
  19. boettg33
    boettg33
    Wakefield, RI
    Sam you could go three sided. That would add more support and allow you to go bigger. While still allowing for good air flow. I love this idea. My deck racks could be modified to allow me to bring them to where my logs are dumped, and then use a bucket loader with forks to move them into the back yard. Only down fall would be getting them on the deck. Though I could stage them right off the deck. Ideas. I love ideas. My wife hates them. It always costs money and time in her book.
    Jason from RI
    Chvymn99 likes this.
  20. Sam
    Sam
    Southern Minnesota
    Yep, they are currently 3-sided. In these pics the open side is facing the door way to the furnace room where all of this is now stacked! I found that if I carefully stacked the open side so as to not put too much outward pressure on the sides they held together really well. Before I discovered that I had to ratchet strap a few "shut" so that they didn't blow apart.
    I know what you mean about ideas! As soon as I mention to the wife that "I've got an idea" she just rolls her eyes.:faint:
    Chvymn99 and boettg33 like this.
