Knife Sharpening
Discussion in 'Axes, Mauls, and Hand Saws' started by Huntindog1, Dec 4, 2014.
  1. Huntindog1
    Huntindog1
    South Central Indiana
    Whats the best system to get knifes sharp enough to shave hair off my arm?
    Or is that something I ought not to be judging a sharp knife by?
    GRIZ, wildwest and Grizzly Adam like this.
  2. bigbarf48
    bigbarf48
    Stone Mountain, GA
    My personal favorite is the worksharp system. Basically a mini belt sander. Comes with numerous guides for different kinds of knives, scissors, etc. and is super easy to use. Just set the blade against the guide and draw it across the belt. I use the red belt, and then hit it with the finer purple belt. After that, the blade gets stropped on my belt and they're always paper shaving sharp after that
    http://www.northerntool.com/shop/tools/product_200431964_200431964
  3. Gunn
    Gunn
    Plover, Wi
    I started off years ago with lansky and served me really well. Now days I have a couple of worksharps including the Ken Onion model and love them. Throw in a strop and its game over.
    dutch, bigbarf48 and wildwest like this.
  4. dutch
    dutch
    Central NY
    splitoak likes this.
  5. pappy88
    pappy88
    Missouri
  6. mdavlee
    mdavlee
    Are you wanting a jig or stone and free hand? I use diamond stones free hand or butcher steel.
  7. Huntindog1
    Huntindog1
    Work sharp system looks interesting to me.
    Been using something like this , it sharpens but not like razor sharp.
  8. bassJAM
    bassJAM
    Cincinnati, OH
    I'm not a fan of the work sharp. It'll get the blade sharp, but it's really easy to ruin the tip at the same time, I wish you could slow down the belt speed when sharpening the tip. It's not worth the risk to me as you can burn it off in one pass if you aren't careful. I've used a Smith system where you clamp your knives in and it has these "butterfly wings" that give you a perfect angle. It works pretty good, although I can't seem to get as good as an edge now that they stopped using arkansas stones and went to diamond. I should probably invest in a leather strop, I think that'd probably give me the edge I want.
    Right now I'm using Japanese water stones. It's taking some practice, but I get better and better results each time I do it. The only thing I don't like is the time it takes to prep (you have to soak the stones first), and it can be a little messy.
    Edit: I do use the Work Sharp belt sharpener for my cheap(er) Victorinox kitchen knives. It works so fast it's nice to quickly touch them up when they need it. But I won't let those belts near my Henkels!!
  9. thistle
    thistle
    Polk/Guthrie Counties,IA
    I use a combination of several natural Arkansas & Belgian stones,DMT diamond stones with water only - no oil for all kitchen knives,chisels,gouges,drawknives,spokeshaves etc.Both lower forearms are normally bald from testing for sharpness after a few minute ritual.
    FarmHand78 and mdavlee like this.
  10. mattjm1017
    mattjm1017
  11. lknchoppers
    lknchoppers
    Lincolnton, North Carolina
  12. bassJAM
    bassJAM
    Cincinnati, OH
  13. mike bayerl
    mike bayerl
    If you want to see the best of the best... Here's Dan Crott's sharpening for Dozier.
    It don't get no better than this!
    Otherwise, I strongly suggest a good diamond stone(s) and good hand sharpening skills. This is what I use, but, I have 10+ years of sharpening knives, chisels, plane blades, etc. If you don't have experience in holding an edge, get a "guide."
    jetjr, cnice_37 and mattjm1017 like this.
  14. BDF
    BDF
    Shaving arm hair is a fine test of sharpness but only for finer tools such as knifes- not much use on axes IMO.
    There are quite a few knife sharpening guide systems that really work well such as Lansky, Razor Edge systems and literally dozens more. It really depends on how much you want to spend and how much 'help' you want from the guide; some are quite simple and require user care while others really do take care of all geometry. Then there are electric systems ranging from the simile disc models like Chef's Choice (not a big fan myself) to the true honing models such as Smith's (expensive but works fantastically well).
    Nothing wrong with hand sharpening either and it can work as well as any mechanical / electrical method but it does take longer and some learned skills. I shave with straight razors and the edges are put on by hand, and are probably the sharpest things short of a diamond microtone but it is a delicate edge and takes a while to generate the skill to develop such an edge.
    I would suggest a simple 'jig' system like the Lansky guide system; they are very reasonable in price and really do work extremely well.
    Brian
  15. golf66
    golf66
    Ah my favorite, sharpening knives. I had the Lansky Diamond system and it was as useless as boobs on a bull. The Spyderco was similarly useless. After watching a few videos, I'm getting good results with the Smiths 8" Diamond Tri Hone. Japanese water stones would probably work similarly well.
    mike bayerl likes this.
  16. Greenstick
    Greenstick
    I use diamond stones and free hand. Light pressure and repeated angle to get you there. A factor that a lot of people don't take into consideration is the quality of the knife steel. You can sharpen junk steel but do not expect an edge to have much life. I suggest a little practice with pocket knives with medium grade steel and once you get them down then go to your $500.00 fillet knives. I also use a ceramic steel to finnish off the sharpening or to do light touch up work. Am thinking on making a strop to have a real finisher.
    PS In a pinch the bottom of a ceramic coffee cup that is raw ceramic with no finish can be used as a makeshift sharpener.
    PullinMyPoulan likes this.
  17. BDF
    BDF
    If you want an inexpensive but very decent quality (and really better than that I think), try Star Shaving: http://shop.starshaving.com/product.sc?productId=75&categoryId=2
    If you charge that strop with 1 micron diamond spray, I think you will find it will put an edge on a knife that is tough to beat with any other method and it is fast and easy too. It will even sharpen ceramic knives.
    Brian
    Greenstick likes this.
  18. laslabjohn
    laslabjohn
    Robeline la.
    I use a edge pro apex 4 guaranteed for life. Very good sharpener. When i sharpen a knife i can push cut newspaper.
  19. laslabjohn
    laslabjohn
    Robeline la.
    And the blade of my knife looks like a mirror literally. I take it down too 10000 grit.
  20. Huntindog1
    Huntindog1
    Nice system!! I watched the video.
