stripped grease fitting
Discussion in 'The DIY Room' started by jetjr, Dec 5, 2014.
  1. jetjr
    jetjr
    Pa/Md line
    I stripped the grease fitting for the pin on my loader bucket. Short of drilling and tapping anyone got any suggestions? It appears to be 1/4" fitting.
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    Ouch! My suggestion was going to be the same as you already offered, redrill and tap. If you can get the fitting out you may be able to run the tap through the stripped threads just enough to get a bite again.
    wildwest and jetjr like this.
  3. rookie1
    rookie1
    If you can deal with it sticking out how about a long fitting? 8981720-21.jpg
  4. jetjr
    jetjr
    Pa/Md line
    It may stick out to far it's the bucket pin.
    wildwest and Stinny like this.
  5. Bret Hart
    Bret Hart
    Central NY
    Loon and wildwest like this.
  6. Stinny
    I've had them get broken off in a few pcs of gear. I always figgered if it was a spinning shaft, in a bushing, I had to replace the fitting... if it was a pivot pin, like your bucket, I'd get grease on it once in a while just by pulling it and lubin' it up.
  7. bassJAM
    bassJAM
    Cincinnati, OH
    Like My IS said, you might be able to get away with just running the tap through. If not, it's not that hard to drill and tap. And having a tap set around (if you don't already) is a life saver so I'd recommend getting a full set rather than just the size you need.
  8. jetjr
    jetjr
    Pa/Md line
    Loon, wildwest, Bret Hart and 3 others like this.
  9. badbob
    badbob
    Try metric fittings,an 8mm may drive in.However if you do not use it often and grease solidifys it will blow out.I also have tack welded fittings in place,ruins the spring under the check ball but can still be greased.Winter is not the time to dissasemble equipment!
  10. Bret Hart
    Bret Hart
    Central NY
    There's another trick you can try if the fitting isn't quite tight enough in the threads.
    Use a sharp center punch about .030 to .040 from the edge of the hole and put 4 or 5 dimples around it. Should tighten it up a bit.
  11. jetjr
    jetjr
    Pa/Md line
    Thats pretty much what I did and then jammed a 1/4" one back in its holding and I am keeping an eye on it.
  12. wildwest
    hope that fixes for you!
    jetjr likes this.
  13. MasterMech
    They come if a few different sizes. You could always drill/tap up to the next size. This requires removing the bucket pin but should really be no biggie.
    Stinny and wildwest like this.
  14. jetjr
    jetjr
    Pa/Md line
    yea if this one wont hold then thats next
  15. MasterMech
    Bucket pin grease fittings are a common problem on many small loaders. The best solution is to relocate the fittings to a recess in the end of the hinge pin.
    I remember when Deere did exactly that about 8-9 years ago with the introduction of the 200/300/400 series loaders and the 260/447/448 backhoes on their 2-4000 series tractors. It was a small change that made a big difference over the life of the product. They also offset the head of the pin so that it could not rotate in the joint. This kept the pins from seizing up and made it much easier to get a dry joint to take grease without disassembling the pin. Having the fitting in the end of the pin makes greasing the joints a snap, as you don't have to reposition the loader/hoe arms to reach all of the fittings. So no big surprise, more folks are actually greasing the pins more often and the joints are wearing a lot less, staying tighter longer than ever.
  16. jetjr
    jetjr
    Pa/Md line
    It's in a recessed area. One of those deals newer grease gun and the fitting liked it to much.
    MasterMech and Stinny like this.
