Flames in Ash Pan?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by wildwest, Nov 25, 2014.
  1. wildwest
    What would you tell your wife to do?
    details on situation:
    Running on sett 6/6. High gusty winds here today.
    Yikes, odd sweet smell, figured it was still paint curing, but then heard popping in the pipe like my old smoke dragons.
    said F 106
    turned off now waiting for it burn out.
    Went outside, chit! My husband did not get the guys on the roof before he left for a trip and the pipe is leaning 30%.
    He will be home tonight.
  2. wildwest
    Just went in attic, all good up there. And noticed a battery operated smoke detector too, I didn't even know he put that in there!
  3. wildwest
    what should I do next?
  4. Lousyweather
    Lousyweather
    I cant comment on the stove, Wild, but I think I'd turn it off......fire in the ash pan indicates overfeeding, which would be a bad burn, which can result on creosote accumulation, which is bad. Check with the manufacturer/dealer on this one....sorry I cant be of more help.
  5. briansol
    briansol
    ct
    Am I the only one who doesn't understand what the OP is asking?
  6. wildwest
    Sorry for confuzzlement. I wanted to know what you would tell your wife to do if she called you and said the flames are high and the ash pan is on fire. I just edited the OP.
    slvrblkk and jtakeman like this.
  7. jtakeman
    Can I use that one? ;)
    I always confuzzled!! :whistle:
  8. wildwest
    Ask papadave , I think I borrowed it from him. Might have been Pallet Pete
    Pallet Pete and jtakeman like this.
  9. Lousyweather
    Lousyweather
    well, I am divorced, but my answer would be to:
    1. Empty the hopper of unburned pellets
    2. Let the stove shut itself down (evacuate all the smoke)
    3. Wait till I get home!
    mike holton and wildwest like this.
  10. briansol
    briansol
    ct
    "It will go out on its own. call me back if it gets worse. if it gets outside of the stove somehow, call the fire dept first " :D
  11. wildwest
    I called Drolet. He said clean it out and it should be fine under speed #4. He was very upfront about that I had a first run model of a redesign. He also told me to check the wing nut to the ignitor faceplate. Yep, melted off!
    He said he is sending out a free wing nut and a new ignitor (that apparently will not warp). How we will get the stub of the melted bolt out I have no idea.
    Cleaned and put back together the stove, crossing my fingers it will light again! Thank you Lousyweather
    jtakeman and Lousyweather like this.
  12. wildwest
    His plane should be landing about now. 3 hour drive and he will be home :)
    papadave and Lousyweather like this.
  13. Lousyweather
    Lousyweather
    I'm impressed! You're a hands-on girl! Although, I gotta say to Drolet: Why have a stove with settings I cant run the darn stove on?! At least they are up-front....
  14. wildwest
    It lit! Phew!
    jtakeman likes this.
  15. Lousyweather
    Lousyweather
    oooh...a romantic evening! :campfire: (sorry, no good romance icons.....this isn't to suggest some weird group thingy tonight at Wild's place, its just the only icon I found which seemed romantic to me)
    will711 and wildwest like this.
  16. wildwest
    mike holton likes this.
  17. wildwest
    Apparently I am lysdexic.
    Drolet thinks it said F160 which is the overheating (exceeded 60K btus) error code.
    Gary_602z likes this.
  18. wildwest
    I neglected to mention he thinks my altitude (7500) may affect the higher higher speeds. Tidbit for DexterDay and jtakeman , he said the serial numbers 3030, or any 303* indicate the the first run on redesign.
  19. DexterDay
    I would check your cap when hubby gets home. Caps get plugged pretty quick when it's cold and your running constantly.
    As for flame in the ash pan? To many pellet and not enough air. Check cap (restrictions), check OAK inlet (restrictions), and clean stove (all internal exhaust passges/baffles.
    Then relight and run on a lower setting. Watching closely.
    My ignitor burned out on my Enerzone last week.. Hoping they have an updated model for me..
  20. wildwest
    Cap on roof, right? or Cap on bottom of cleanout tee? I checked the oak vent to make sure my hired help did not stack pellet bags infront of it. He did not, remembered it from last time.
