whats the new famdangled oil to use these days?
Discussion in 'Chainsaws and Power Equipment' started by Freakingstang, Nov 20, 2014.
  1. splitoak
    splitoak
    jefferson co wv
    Hp ultra 40:1
    bigbarf48 likes this.
  2. DexterDay
    My racing days was Castor 927 (nothing smells better :dex:)
    I have some Amsoil Dominator left, but have a few liters of H1R.
    clemsonfor and MasterMech like this.
  3. lukem
    A certain pistol packing primate convinced me to run belay h1r.
    clemsonfor and DexterDay like this.
  4. bigbarf48
    bigbarf48
    Stone Mountain, GA
    I don't think I've ever smelled my 2 stroke oil. Am I missing out?
    clemsonfor and the GOAT like this.
  5. Adirondackstihl
    Adirondackstihl
    Motul 800 2T
    32:1
    Ron660 and mdavlee like this.
  6. Moparmyway
    Moparmyway
    New York
    Best oil you can get
    clemsonfor, mdavlee and bigbarf48 like this.
  7. Moparmyway
    Moparmyway
    New York
    Ha ha ........
    Only kidding !!
    I run VP with eithor one of the two added for 32:1
    mdavlee likes this.
  8. mdavlee
    mdavlee
    The belray makes my noise run and stihl ultra gives me a headache. K2 is leaving a good film even better than motul 800 on the same tune.
    clemsonfor likes this.
  9. Jon1270
    Jon1270
    Pittsburgh, PA
    Now I want someone to produce a Scratch 'n' Sniff card so I can sample these oil smells without buying them all.
  10. Freakingstang
    Freakingstang
    klotz smells the best of any two stroke oil I've used used or smelled.... hard to find in these parts tho
    mdavlee likes this.
  11. mdavlee
    mdavlee
    I could do belray, motul, maxima k2, 927, and maybe klotz. They smell a bit different when burnt then they do in the jug.
    bigbarf48 and Jon1270 like this.
  12. HittinSteel
    HittinSteel
    Wooster, Ohio
    I have stihl ultra, woodland pro, and echo powerblend mixing at 32:1. I might try some fancy stuff when I run out :cheers:
    mdavlee likes this.
  13. Jon1270
    Jon1270
    Pittsburgh, PA
    In the springtime I bought a broken weed whacker that came with one of those big Sam's Club-sized pretzel jugs full of little orange bottles of Stihl oil. Today I'm planning to buy a couple of other saws, and they're to come with several 6-packs of the Stihl silver bottle. I may never get to try the fancy stuff.
  14. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    If your saws arent locking up... Use what you have been :)
    clemsonfor, Chris F and Chvymn99 like this.
  15. JRSDWS
    JRSDWS
    Central Illinois
    Maxima K2 at 32:1 as of late plus I have a quart of Amsoil Dominator to use up.
    MasterMech and Chvymn99 like this.
  16. NH_Wood
    NH_Wood
    I'll be out of the Jonsered oil I bought at TS a while ago on the next mix - just received 12oz of Belray H1R to give that a try - but might not be for a while - getting close to done cutting for the season and one more gallon or so of mix should do it. I've been mixing at 45:1 - any reason to change this when I go to the Belray? I'm seeing 40:1 and 32:1, but 45:1 has been working well in all my saws. Cheers!
    Chvymn99 likes this.
  17. UncleJoe
    UncleJoe
    SC Pa
    I haven't seen it mentioned yet so I guess it's not the most popular kid on the block.
    I've been using Optimal (Opt2) for nearly 20 years. Never had a problem except the one time one of my ex-employees dropped a 200T into a creek and then tried starting it right away instead of drying it out and cleaning it first. Can't blame that on the oil though. I use it in all my 2 cycle gear.
    clemsonfor and Deacon like this.
  18. WKEND LUMBERJAK
    WKEND LUMBERJAK
    This is what I am using right now I have used about all the major saw brands 2cycle mix. at about 32 to 36:1. I can't tell a difference between any of the major saw oils.
  19. WKEND LUMBERJAK
    WKEND LUMBERJAK
    Why the lucas never used it? not busting you just asking.:popcorn::popcorn:
  20. mdavlee
    mdavlee
    $9 quart for it. It coats the inside good on Matt's 7900 when I took it apart.
