Thinking of up grading
Discussion in 'Modern EPA Stoves and Fireplaces' started by WKEND LUMBERJAK, Nov 16, 2014.
  1. WKEND LUMBERJAK
    WKEND LUMBERJAK
    Hello every one been a member here about a year. just started getting involved some I have a U.S. stove company hot blast model 1300 Hot Blast for 14 years has always been a good indoor furnace. ??? is who has used one of these and what did you up grade to?
  2. jeff_t
    jeff_t
    SE MI
    I heated with a 1557M for a few years. Got tired of running to the basement all the time, and setting an alarm on the really cold nights so we didn't wake up to a 60° house. The thing makes a ton of heat, and burns a lot of wood. I burned good wood as clean as I could, and got away with cleaning the chimney mid and end of season. It was what I could afford at the time, and I don't regret it. I still have it in the basement, disconnected from the ductwork, and burn it if the BK needs a little help (like -20 and windy o_O) or if I want to do something down there.
  3. WKEND LUMBERJAK
    WKEND LUMBERJAK
    Jeff, I don't have mine into duct I have it strategically installed next to the stairs in the basement heat rises. we vary rarely ever wake up to 60. usually my wife keeps it in the mid to upper 70's. only time we turn on the blower is when it get's below 10 and the wind is blowing hard. We keep the bedrooms closed sleep better in the cool.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    how many sq ft is your home?
  5. WKEND LUMBERJAK
    WKEND LUMBERJAK
    Living space 1300 basement 1300 basement never gets below 50.
  6. wildwest
    Do you NEED to upgrade? It sounds like your setup is working well for you?
  7. WKEND LUMBERJAK
    WKEND LUMBERJAK
    Not yet just trying to see what others are using. so if I run across a deal. I will know it.
