Mower service day.
Discussion in 'Chainsaws and Power Equipment' started by bogydave, Nov 12, 2014.
  1. bogydave
    I put it away with a mess under the deck.
    pulled it off, pulled the idlers, gave them as much grease as it could.
    seal on the bearing don't come of like on the spindles.
    Greased the spindle bearing, just popped of the bearing cover
    & packed some new grease in the bearings & popped the seal cover back in.
    Cleaned the deck, gave it a good coating of oil.
    Hung from the ceiling to get it clean & remove the blades.
    Oil filter & oil change.
    Just needs the blades sharpened & put away for winter.
    raybonz, HoneyFuzz and stuckinthemuck like this.
  2. bogydave
    Greasing the spindle bearings : I used a scribe to pop the bearing covers/seals
    wildwest, Cut4fun, raybonz and 4 others like this.
  3. NYCountry
    NYCountry
    Mohegan Lake NY
    Keeping busy ehh..what do u use to sharpen the blades? What kind of grease do u use
  4. Bluelou
    Bluelou
    Northern il.
    Grass grows up there ?
    wildwest and tuneighty like this.
  5. bassJAM
    bassJAM
    Cincinnati, OH
    I'm still waiting for all the leaves to drop so I can chop them up with the mower. I might be doing that in Carhartt's though with the way the weather is looking. At least I can heat my garage though for the oil change, greasing fittings, and sharpening the blades.
  6. Machria
    Machria
    Long Island, NY
    Yes of course! It's was just legalized in Alaska via this months elections along with Oregon and Washinton, DC. :thumbs: Here is the universal icon for a group of dudes firing up a doobie: :campfire:
    Now the fact Washington DC legalized is kind of ironic. We all know the politicians in Washington have been doing bong hits for years!! At least I hope so, cause they can't be as stupid as they act, can they?? :D
    :pete: We are going to need an additional sign to the "beer" one!! :D
    Having fun yet?? :banana:
  7. Xjcacher
    Xjcacher
    West central Arkansas
    Best thing I've found is using a flap disc on an angle grinder. Gets them good and sharp and don't take too much metal off.
    wildwest and raybonz like this.
  8. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Looking good . That mower will last a looong time with that kind of maint. !!!
  9. bogydave
    Thanks
    That's the plan :)
    good idea
    Where you get the discs ?
    I get them close with the bench grinder, trying to not overheat them
    Then hand file . Good exercise :)
    Got 2 sets to do, sharpen & oil them , ready when needed.
    wildwest and HoneyFuzz like this.
  10. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Have had good luck using the good quality frame restoration paint on the underside in the past . Its strong..and holds up good . But I find myself using oil more as well !
  11. bogydave
    Repainted it once, 2 part epoxy. Didn't last long
    Clean & oil now & then is much easier,
  12. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Agreed 100% !!!
  13. savemoney
    Get some sheep and you won't need that lawn mower!
  14. bogydave
    :rofl: :lol:LOL
    Like a horse is better than an ATV. but
    I park the atv & the mower, Done deal ,
    No food no vet & no care needed , day in & day out 365 days a year. :zip:
  15. savemoney
    Yes, but you miss out on all that fertilizer :p. Also a lot less noise. Just think of the wooly wear you are missing out on.
  16. bogydave
    True
    Not sure I'm missing out on any wooly were though. Itchy stuff.
    savemoney and wildwest like this.
  17. Xjcacher
    Xjcacher
    Most hardware stores carry them I even carry them in my auto parts store.
  18. MasterMech
    Having raised sheep from the time I was about 3 until my early twenties, I can assure you that while they are excellent and efficient mowers, they are anything but quiet. :confused:
  19. bogydave
    Difficult to do an annul PM & park them for 6 months too . LOL :)
    savemoney, MasterMech and wildwest like this.
