stove chatter
Discussion in 'Modern EPA Stoves and Fireplaces' started by tuneighty, Nov 12, 2014.
  1. tuneighty
    tuneighty
    South Central PA
    This 30 makes some chatter. Any one else experience this? Just getting it going before bed and you can tell it's getting up to temp by the creeking noises.
    Chvymn99 and wildwest like this.
  2. wildwest
    My old smoke dragon & rigid pipe used to creak and pop as it got hotter. I associated those sounds with warmth :fire:
  3. papadave
    Mine makes a little noise coming up to temp....pretty normal.
    My old stove did the same.
    HDRock and wildwest like this.
  4. tuneighty
    tuneighty
    South Central PA
    It's not a bothersome or concerning noise, just the ole girl letting me know she is happy, almost saying "feed me, feed me. "
  5. papadave
    Sounds like a light tapping or pinging to me.
  6. tuneighty
    tuneighty
    South Central PA
    That's it.
    My IS heats my home and wildwest like this.
  7. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I get the same on the 30. The Defiant taps and pops also as it comes up to temp.
  8. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    The Heritage also did it's fair share of creaking.
    splitoak and wildwest like this.
  9. Grizzly Adam
    Grizzly Adam Guest
    The Lopi, USSC, and now the Drolet all do this.
  10. Scotty Overkill
    Even my Napoleon's do this. Both the 1900p freestander and the NZ3000 fireplace. Pings, tings creaks and taps. Once up to temp it quits. Completely normal........
  11. HDRock
    oh yeah you can tell what your stove doing without looking at the fire or the thermometers.
    expansion and contraction
  12. Certified106
    Certified106
    In The Hills
    The T6 will make a few creaking noises as it comes up to temp. Ii is just the nature of the beast as the material expands at different rates when one are is colder and the other is hotter. Should be fine
  13. Highbeam
    Highbeam
    My NC30 does a little flutter thing when the fire is hot but the flue hasn't fully warmed yet. A mini-huff and you can see the flames pulsing rapidly as the flue's suckage oscillates. It sounds like a mexican person rolling their Rs. The stove doesn't shake though, just makes that noise.
  14. splitoak
    splitoak
    jefferson co wv
    Yup....(does)....i learned alot about my stove by reading BAR's posts..on "the other site"...:BrianK:
