Kreg jigs....anyone use them? what do you think?
Discussion in 'Hobbies and Interests' started by Lousyweather, Nov 12, 2014.
  1. Lousyweather
    Lousyweather
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    I have used them when making certain pieces of furniture. I like them, they have a purpose and they work.
    For the money (at the time I got it) the price seemed reasonable. But since I'm working 2 jobs
    I have not had any projects in the last 6-7 years so I haven't used it at all.
    I bought mine from Grizzly, paid probably $40 back then. And the one I have isn't quite as elaborate as the one you linked.
    Scotty Overkill and Lousyweather like this.
  3. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I believe harbor freight has a knockoff at half the price as well. I almost bought on a few years back. Ill see if I can find a link for ya.
  4. bigbarf48
    bigbarf48
    Stone Mountain, GA
    I don't have one, but have heard nothing but praise for them from others that do
  5. Lousyweather
    Lousyweather
    thanks, Pete!
  6. Pallet Pete
    Ovid
  7. ironpony
    ironpony
    Mid Ohio
    great tool. I have the one for $99. just used it over the weekend to build the daughter a microwave cabinet. have used it for a lot of cabinets and shelf builds. you have to think it thru and plan but it makes super strong tight joints. takes a little practice, but is overall easy to use
    fishingpol and Lousyweather like this.
  8. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I have the K 4 set up. For furniture and cabinet building, it is excellent. I rarely use my biscuit joiner or dowels to make connections. You can even join board edges together for a tabletop. I have made an oak bookcase, walnut bookcase, my daughters desk and now one for my son. The joints are tight and you can buy different species of plugs to match your wood. The plugs are not standard dowel sizes, as I have already tried to save a few bucks. The Kreg plugs are nice and snug. If you are making furniture or other projects that require joinery, go for it.
    Walnut and poplar book case
    quarter sawn oak bookcase
    cgraham1, jeff_t, ironpony and 6 others like this.
  9. Lousyweather
    Lousyweather
    good looking stuff, fishing! Yea, historically, I used biscuits for joining, as in a top, but perpendicular joints, stiles and rails, etc can be problematic........I have heard about them....sounds good.......do you glue and screw, or just screw them? ive heard both ways......
  10. fishingpol
    fishingpol
    A little glue never hurts. You can put two screws relatively close to each other without splitting. Don't over torque the screws. It also makes flush faces where the joints meet up. Setting the screws is really satisfying when the joint pulls together snugly and securely. Oh, and no real waiting for glue to set, screw them and move on to the next one.
    papadave and Lousyweather like this.
  11. bogydave
    K-4
    Nice jig . I use it a lot.
    Great way to hide screw & make strong joints.
    Lousyweather and fishingpol like this.
  12. papadave
    Just about to pull the trigger on the K4 or K5 system.
    No experience with it .......yet.
  13. CTYank
    CTYank
    CT Panhandle
    I've used a basic Kreg kit, can't tell you which offhand, for at least 10 yrs. I use it for all sorts of edge-to-edge and butt joints, sometimes with biscuits to aid alignment & add strength. Enormously better than brads.
  14. Scotty Overkill
    I'm getting one. How I've made it this far in life without those jigs is beyond me.....
    I'm also going to buy a set of those bits for turning dowels on the ends of small logs for making rustic furniture. I've got some idears.......
    papadave likes this.
  15. unclefess
    unclefess Guest
    as a full time woodworker i will say they are very good much faster then biscuits or dominos i have used them for many jobs
    if you do case work get a right angle clamp as well for assembly help it will pay for itself in one use
    for about 20.00 you can get a basic tool if you want to try it out
    pocket hole joinery has been around for a long time but kreg has made it easy
  16. chris
    Got the pocket hole jig system works well also have the their miter fence assembly on my PM66 table saw works very well also.
  17. bigbarf48
    bigbarf48
    Stone Mountain, GA
    I saw an ad for those dowel-turnin machines in a magazine recently. I was surprised how inexpensive they are. Made me think about getting one too. I made these legs for a foot stool for my mom, made out of a 1/2 round of red oak. I roughed it out with the saw, and then chiseled and sanded till round. A machine would sure be quicker though :D
  18. Scotty Overkill
    I use my lathe to more or less the same effect, but those jigs for doweling the ends of logs are slick. You can use them in your cordless 1/2" drill!
  19. Jon1270
    Jon1270
    Pittsburgh, PA
    FWIW, boring the pocket holes is one job for which a plug-in drill is better than a battery-powered drill, because higher rpm's make for a cleaner cut.
  20. Lousyweather
    Lousyweather
    pulled the trigger on the K4 master jig........and thanks for the helpful hints......making a kitchen table for the gf for Christmas....top's done, but still need to cob together the base frame. When I saw the advert for the Kreg, looked into it, and it seems they are a pretty good thing.....no negatives really
