My tree guy just called.
Discussion in 'The Wood Pile' started by Paul bunion, Nov 8, 2013.
  1. Paul bunion
    Paul bunion
    He said he has a short load of logs that he can give me tomorrow, would I like it? 1/2 a truck or so. What am I supposed to say, "if you want to back your truck down my driveway and unload it has to be full"?
    I got the leaves out of the way and the stringers set up. Time to go get some fresh mix.
    As usual I will probably not be at home when he delivers because I will be at the soccer field.
  2. bogydave
    Good deal
    MOVE THE GAS JUG !
  3. Oldhippie
    Oldhippie
    Ashby Ma
    Awesome!!
  4. papadave
    Oh no you don't. Never bring a short load......It's a full load or nothing, mister.
    If you can get it processed quickly, I wouldn't worry about the "stringers". If it may take a while, I think I'd beef up the ones in back.......they look a little wimpy.
    So, :popcorn:
  5. Paul bunion
    Paul bunion
    Stringers are so I can slide/roll the wood into the driveway for cutting. Doing that much on cutting on the lawn is pretty detrimental to it. Dust/chip/bark cleanup is much easier when done on the driveway
    And I found this in when I returned from my daughters soccer game (they lost). Not a bad load at all, 14 pieces. Estimate it to be 2.5 cords. White oak, red oak, ash and a lowly piece of sycamore. First time I've ever had sycamore.
    First log on the cutting deck is red oak, 14' long, 21", 2nd is ash 24" at the but side, gets a bit knotty, it might be a pita to split.
    I don't know how he split the log length pieces although he did say that he was doing that in order to give the wood away.
  6. thistle
    thistle
    Polk/Guthrie Counties,IA
    Great stuff.Grab all you can find room for.
    Some years ago when I split some 6' & 10' White Oak & Western Red Cedar ( Cedar was a 80 yr old phone pole Qwest left for me in backyard) for rail fencing/posts I used sledge/wedges & a couple heavy wooden "gluts" just leapfrogging them down the length....
    Not easy & takes some patience but can be done if you don't try to do too much at once...
  7. bogydave
    Prime wood there.
    He can drop some off here anytime
    Even 1/4, 1/8, 1/16 loads . LOL :)
    papadave and 343amc like this.
  8. Paul bunion
    Paul bunion
    I would take your view over the free wood any day.
    cmag likes this.
  9. Steve
    Steve
    Stouffville, ON
    The guy landed the load onto your stringers?
    Nice haul BTW
  10. Backwoods Savage
    Paul, that is great. I wouldn't worry too much about that ash being hard to split.
  11. Paul bunion
    Paul bunion
    I got 2/5 of it cut up this afternoon. I think the pre-split pieces were a failed tree, there wasn't a mechanical mark on any of it and the pieces were cut to separate lengths. It split apart standing. My 029 Farm Boss with a 20" bar definitely isn't up to the task of 24"+ logs. Spent forever cutting them up with the nose burried. I need to get a bigger bar with skip chain or a bigger saw all together.
    Might have some hickory that I mistook for for oak at first. It does grow here but it isn't that common. I've never received any hickory logs before.
    Cheers
  12. Paul bunion
    Paul bunion
    Yes, he always lays it out flat on my metal. This time I left him a note asking for the biggest ugly logs on the 6x's so I wouldnt have to mess with rolling them and he complied. Only complaint I have is no cherry, boo-hoo, a friend of mine has a resturant with smoker and I can convert the cherry into a golden beer mug when I have a supply.
    Steve likes this.
  13. Certified106
    Certified106
    In The Hills
    Wow, what I wouldn't give to have wood delivered to me like that! Congrats and treat that guy right he is awesome! That is an incredible score! :thumbs:
  14. thistle
    thistle
    That be Shagbark alright.... You're in for a a treat.Same intense heat (sometimes a little more) as White Oak,but dries in half the time - 12 to 18 months once split/stacked & in a spot with sun/wind.
    What's in the glass? I can't quite make it out...
  15. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Nice load.
  16. Paul bunion
    Paul bunion
    That's a Ramstein glass with Defiant hefeweizen in it. Both are local breweries.
  17. papadave
    Well, I'd take that kind of load any day.
    Give that guy a glass of what you're having.:thumbs:
  18. thewoodlands
    thewoodlands
    We all need a tree guy like that, nice job.
    Steve and papadave like this.
  19. Pyroholic
    Pyroholic
    mid michigan
    If you haven't done a muffler mod on that 290 you should think about it. Mine will pull 20", full comp, rs chain while buried quite well now. Not like it keeps up with the 038 mag or anything, but it is extremely noticible in performance, sounds sweet, and was free. Just a thought, although I would never endorse NOT getting a new bigger saw if you have the funds. Either way the 290 is sorely in need of an mm.
  20. Chvymn99
    Nice load, especially when they are in log length. Plus you got a nice selection there. :thumbs:
    papadave likes this.
