Repairs to the wood hauler
Discussion in 'The Wood Pile' started by bogydave, Nov 8, 2014.
  1. bogydave
    Broken tail light.
    I seem to break one or 2 every year.
    The wood area has no real goo turn arounds for a 16" trailer.
    Been saving the parts.
    used some duct tape & a red lens off an old one to get this one looking better. Fits close enough.
    Most likely I'll break it next year anyway.
  2. bogydave
    Remember the flat tire on the trailer
    Time to fix it.
    Using a plug.
    Fill & test:
    AARG, it leaks, & I found at least 4 other leaks.
    Called the tires shop, $ 128 for a new tire. Told them I only wanted one, they said $128.
    To the auto store for a tube. $18
    HDRock, Stinny, Gasifier and 5 others like this.
  3. bogydave
    To/from the store for a tube.
    Break the bead with the hammer bead breaker,
    roll one side off the wheel, (used dawn dish soap to help)
    Install tube, inflate , remove the spare & put it back on the trailer spare mount.
    A simple tire job turned into an several hour repair.
    Noticed 2 other tires have tubes, maybe their about worn out.
    Hope to get a few more years out of them.
    Was also planning to grease the bearing & check/ adj the brakes.
    Maybe tomorrow or Monday.
    to be continued :
    HDRock, Stinny, Gasifier and 6 others like this.
  4. Greenstick
    Greenstick
    I'm really tempted to find square tube big enuf to fit over my trailer tail lights weld some mesh over one end then tack it to the trailer. It seems to be a pair a year and if I had done that fix years ago I wood be $ ahead.
  5. Greenstick
    Greenstick
    Not sure of tire size but I have bought trailer only tires. Put 4 15" tires on my camper this spring for 320 $.
  6. Freakingstang
    Freakingstang
    rookie1, Backwoods Savage and GrJfer like this.
  7. billb3
    some people put brush guards over/around their lights
  8. bigbarf48
    bigbarf48
    Stone Mountain, GA
    I do the same thing to my lights dave. I've gone through one set already :rofl: :lol:
    clemsonfor and Backwoods Savage like this.
  9. tuneighty
    tuneighty
    South Central PA
    The one trailer we use, has the taillights housed in 6" steel pipe. They are recessed in an inch or 2.
    Gasifier and Backwoods Savage like this.
  10. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I hate putting tubes in tires. It's a great day when I can get one in without putting a hole in it.
    Backwoods Savage and tuneighty like this.
  11. bogydave
    I didn't want to replace the light fixture, it is working. LOL :)
    Think I'll try mounting them on top of the angle next time. (pretty sure there'll be a next time )
    Other side is broke too, but not so bad it needs replaced, + it helps as a back up light :)
    These were both new this year. No need to buy the expensive ones, they'd get broke too.
    If I had a welder I'd put a guard around it. But
    I bet I could still break them.
    Tire still holding air :)
    41° windy, cloudy
    Gasifier and papadave like this.
  12. Backwoods Savage
    Yes, on the top they will be a bit better but you still have to watch that brush. As for the fixing of tires, I've graduated to taking them down to the tire shop. Sure saves my body...
    tuneighty likes this.
  13. bogydave
    I keep saying I'm gonna cut some of the trees & brush to make a good turn-around
    Need to make it a higher priority next year,
    tail light replacements & repairs are getting old.
    Yea, was gonna take it to the tire shop
    they closed early on Sat. & the auto parts store had a tube.
    The tire hammer's not too bad but the 6 ply tire was real stiff,
    Used a couple 2x4s to pry it open to put the tube in.
    Lots easier than an ATV tire by a long ways :)
    Stinny and Backwoods Savage like this.
  14. Backwoods Savage
    For sure. Don't you just love the small tires?!!! For sure those always go to the tire shop.
  15. bogydave
    ? for mechanics
    Electric trailer brakes.
    I adjusted the adjuster (in the drum) on the trailer brakes to just lightly rubbing.
    Hooked up a 12 V battery to the trailer plug, brake wire
    at a full 12 volts, all 4 lock up tight, by my not able to turn my hand.
    Is that a good test ?
    The brake modulator on the PU, on the lightest setting, when empty locks up the tires on gravel roads,
    ( I adjust the slider to off, all ok ) ,
    On pavement it's ok with minimum braking. Any higher setting locks up the tries on pavement ,
    But empty not a big deal to run with brakes off.
    When loaded, I adjust brake modulator in to where I can feel it slowing everything down, by just barely pushing the pedal to where light comes on but no
    braking from the PU yet, just the modulator sending volts to the trailer.
    Not even full modulator voltage locks up the trailer brakes on pavement when trailer is fully loaded. But I can feel it pulling pretty hard & slowing pretty hard.
    OK ?
    HDRock likes this.
  16. Gasifier
    Good work bogy. You have more patience than I. I would have waited for shop to open and brought tire to shop. LOL Did something else while waiting. And I probably would have bought a new set of the cheapo tail lights at the cheapo store. LOL
  17. bogydave
    Cut/removed/replaced some of the rotten deck boards.
    Just spliced in some short peices. No need to buy new 16' treated bords yet,
    Should get a few more years out of the deck now.
    Had some man-o-war deck stain. Figured it might help water resistance.
    Maybe help the wood last longer.
    Nice day , worked with the garage door open.
    Trailer done,
    parked out back, out of the way for winter.
    The pictures:
    On to another project :)
  18. boxygen
    boxygen
    All of this is looking very familiar. I like it when my neighbor borrows my trailer, he always brings it back with something repaired on it. Nice job Dave.
  19. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Deck looks good dave :thumbs:
  20. HDRock
    how thick are them boards?
