It's that time of year again. Leaf season.
Discussion in 'Chainsaws and Power Equipment' started by TurboDiesel, Nov 8, 2014.
  1. TurboDiesel
    Ok. I'm looking for some help and opinions.
    I'm looking for a backpack blower.
    I have used a Stihl before while helping a landscaper friend clean up leaves but I don't know the model number or prices. I do know that thing moved some leaves.
    I like Stihl machines but I'm not brand loyal. I want one that starts easy and fast....and Blows
    Thanks
    Tim
  2. bocefus78
    bocefus78
    For a stihl you want a br600. Biggest they make.
    Only one on the market that blows more air cfm is the shindiawa.
    Hth.
  3. w8ye
    w8ye
    Mansfield, Ohio
    I mow my leaves. I mow to discharge towards the flower beds. 80% are chewed up and gone before I get to the flower beds. I then use a Echo PB-2400 hand blower to clear off the patio etc.
    Then the next day, all the neighbor's leaves are in my yard.
    Mitch Newton, basod, Stinny and 7 others like this.
  4. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    +1! Shindaiwa EB854 or EB854RT 79cc two stroke, Stihl is nice but won't compete with these, although the Stihl MSRP is less. Perhaps you could find a NOS Solo 471/472 but not the 'Kat' version, 'Kat' is CA CARB compliant crapola!
  5. MasterMech
    +1 on the BR600. (I own one) Light, comfy, and all kinds of power. There are a handful of blowers that have a bit more power but they all are heavier, louder and not as comfy to wear. Plus they can be up to $100 more than the Stihl. Go figure.
    If you absolutely gotta have the most power, the Husqvarna 580BTS or it's RedMax twin would be it.
    HDRock likes this.
  6. bigbarf48
    bigbarf48
    Stone Mountain, GA
    I used a redmax blower on the tree crew I worked for, and they were awesome. I'll see if I can find out the model #
  7. CTYank
    CTYank
    CT Panhandle
    Seems RedMax blowers are now made in orange resin, as Husqys. Got a 50 cc 150 bt a couple years ago for $225 delivered from VMInnovations dot com. Wet leaves not a problem. Strato engine a plus. NOT a 4-mix engine, a bigger plus.
    HDRock likes this.
  8. Paul bunion
    Paul bunion
    Same idea here but my neighbor had his big red oak cut down last year. Now only the wood is in my yard in pieces that are about 16" long stacked up very neatly and there are many fewer leaves. :)
    TurboDiesel and w8ye like this.
  9. HittinSteel
    HittinSteel
    Wooster, Ohio
    I feel the same about my re-furbed 150BT. I've had it 4 years and would buy another in a heartbeat.
    HDRock and My IS heats my home like this.
  10. Jon1270
    Jon1270
    Pittsburgh, PA
    How big is your yard? I acquired a br600 without really intending to, as part of a package deal when buying a used saw. I don't have much to compare it to, but my property is so small and the blowing goes so quickly that I can't help wondering whether I'd be happier with a lighter, less-powerful model. The br600 may be light for its class, but it's heavy enough to feel like I'm strapping myself into the robotic exoskeleton from Aliens just to take the trash out. I wonder what's the MS260 of backpack blowers?
    Speaking of 4-mix engines, is adjusting the carb on them similar to standard 2-stroke engines? Mine dies at idle when hot, but I haven't tampered with the screws yet.
  11. TurboDiesel
    Well they are pricey and they are heavy, but that BR600 blows!
    My dealer wants me to run aviation fuel in it at $7.00 /gallon. Yes he sells this fuel....
    Any thoughts? I ran this fuel in a car many years ago. I know it's good, I know there is no ethanol in it, but Stihl built these machines to run on the junk fuel we have now.
  12. MasterMech
    They adjust pretty much the same way except you don't set them rich ("four-stroking") at WOT like you would a saw. They are a blower so they are always under load, and a 4-mix engine is always four-stroking. ;)
    Tune the L for stable idle and best throttle response, tune the H for max power/rpm. I can check to see what the max spec is for a Br600.
    My yard is about 1 acre. 90% of the year the BR600 is overkill but it makes quick work of the heavy leaf cover I get repeatedly in the fall. I actually try to mow often with a mulch kit on to minimize how many leaves I have to blow around.
    Jon1270 likes this.
  13. Jon1270
    Jon1270
    Pittsburgh, PA
    Thanks. I recently acquired a tach so I can do it that way. Of course to tune it all I'm going to have to improvise a tool, since it has odd screws without slots.
    MasterMech likes this.
  14. Cut4fun
    Cut4fun
    OHIO Redneck
    When I was looking into this not long ago. I decided I would have went with a real 2 stroke or older stihl version before the 4 mix ones. Sorry just not a fan of 4 mix.
  15. Bluelou
    Bluelou
    Northern il.
    It's funny most of my leaves end up in my gutters and not on the ground, at least that's how it seems to me.a friend of mine has the br600 what a wicked piece of equipment almost a little to much for home owner use.heres my two blowers the echo back pack is almost 20 years old(pb-46 ht)the only thing I have done to the echo is one carb rebuild and replaced fuel lines i think one or two times .if and when it brakes i will try and find the parts to fix the thing , image.jpg image.jpg i hope to have it forever. Picked up the stihl hand held about a year ago and does well for what it is.
  16. MasterMech
    Echo blowers are indeed nice pieces of equipment. That said, my Stihl SH86 does most of the clean-up work around here. :yes:
  17. Cut4fun
    Cut4fun
    OHIO Redneck
    I ended up buying the gutter attachment. Makes things way easier twice a year.
  18. HDRock
    Got leaves ? Get one of these :)
    Just got my re-furbed 150BT. from VMInnovations this year , $220, free shipping, love it , starts easy, runs great and really blows ,wet leaves, sticks :thumbs::banana:
    I have 3/4 acre trees all around put 4-5 tanks through it .
    It does a good job
    savemoney, Mitch Newton and raybonz like this.
  19. raybonz
    raybonz Moderator
    Carver, Mass.
    Been using my riding mower with a bagger on it and it makes leaves easier than ever! I clean up leaves many times as they all drop at different times.. One large oak is almost naked and 25' away I have an oak tree loaded with leaves.. The maples and cherries have lost most of their leaves but the big crab apples still have their leaves. I figure 3 or 4 more times and I can put the rider to bed for the year.. I hope..
    MasterMech and HDRock like this.
  20. NewToStihl
    NewToStihl
    Central Indiana
    I can't speak much for other brands, but I have friggin' ton of leaves and my Stihl BR600 was a game changer. Comfy for hours of nonstop use, loads of power and excellent fuel efficiency.
