oil plug on a huskee 22 ton
Discussion in 'Chainsaws and Power Equipment' started by firecracker_77, Nov 7, 2014.
  1. firecracker_77
    firecracker_77
    IL
    Anyone know where the plug is located? Briggs engine... 1.5 year old model. About how much oil?
  2. lukem
    Under the motor. 3/8 female plug. About .5 quart.
  3. firecracker_77
    firecracker_77
    IL
    I looked and maybe I'm blind. Anyone got a pic?
  4. bogydave
    You mean like a allen head inny ?
  5. Well Seasoned
    Just ran out and took a picture. Sorry it kinda sucks, had to climb over equipment in slippers. Use a socket wrench w/o the socket attached, will work best. It's the recessed bolt in picture.
    firecracker_77 likes this.
  6. BillinTX
    BillinTX
    Northeast TX
    Raise the splitter up by the tongue until it sets on the foot.
    The plug is easier to get to that way.
    After you get it loose set it back down and drain the oil.
  7. firecracker_77
    firecracker_77
    IL
    Thanks guys. ..valuable tips here.:D:thumbs::dancer:
  8. DexterDay
    This is what I do.. :D
  9. jeff_t
    jeff_t
    SE MI
    I used a couple of street elbows, and a short piece of pipe. I put a coupler on the end of the pipe to put the plug back into. Could use a cap, I suppose, but I couldn't find one in my coffee can fill of fittings. It moves it away from the tank, makes it far easier to get out, and is way less messy.
    HoneyFuzz likes this.
  10. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I too like this way !! Takes a little time ...but after that it saves time :)
    jeff_t likes this.
