Ceiling to floor pass thru fan
Discussion in 'The DIY Room' started by Trilifter7, Nov 6, 2014.
  1. Trilifter7
    Trilifter7
    Waynesville, OH
    Been considering this for a while now and finally did it. I bought a Tjernland RB12 register booster fan for the upstairs room above the stove room. I also installed a ceiling register in the stove room as the intake for the register booster upstairs. The fan uses the floor joists as a duct or chase for the air to flow thru. First test tonight but seems to be working perfectly. I read 82 deg downstairs in the intake register and 79 deg upstairs in the register booster!! Should help keep the stove room from getting crazy hot and help upstairs stay a little warmer. I'll report back as I use it more.
    milleo, rookie1, OhioStihl and 4 others like this.
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    I'm my 1880s Victorian farmhouse I had 2 gravity type vents like yours Trilifter7 , inbetween two floors. I know in my case they may be grandfathered because of them being original to the house but I was bagged on one of them in my stove room during a stove inspection in 2008. I know they are illegal in today's building code but can be allowed with a fire door. So the inspector asked me to install one or close it off as a fire hazard. I ended up installing a fire door on the stove room register in order to keep the vent. Just wanted to share that because some folks might not know.
    rookie1 and papadave like this.
  3. Trilifter7
    Trilifter7
    Waynesville, OH
    Wow I never bought of that! Thanks for the info
  4. coal reaper
    coal reaper
    Nj
    very nice. how loud is the fan? i want to get the kit that goes between the studs for one of our rooms if i decide to put in a small pellet stove.
  5. cnice_37
    cnice_37
    Yep, what MyIS said...
    Care to run an experiment with and without the fan? I bet you don't even need the fan in there to see some pretty significant improvements.
    billb3 likes this.
  6. Trilifter7
    Trilifter7
    Waynesville, OH
    You can barely here the fan. It sounds like a standard register blowing air when the heat or ac is on.
  7. RockyFordOak78
    RockyFordOak78
    Raleigh, NC
    I am glad you posted this. I am thinking about the same thing. Can you post a link where you found this fan? Please update us on how well this works. Thanks!
  8. Trilifter7
    Trilifter7
    Waynesville, OH
    I offset the registers by about 10 feet so I doubt there is very much natural air movement there. I could try it still and see if I get draft or increase in temp out of the open register.
  9. Trilifter7
    Trilifter7
    Waynesville, OH
  10. cnice_37
    cnice_37
    Ahhhh, no then the fan makes plenty of sense. I think the only thing holding me back from doing the same thing is having kids who are very light sleepers. Stove room directly beneath bedrooms, so I'd end up closing at night and opening in the morning.
  11. Trilifter7
    Trilifter7
    Waynesville, OH
    Here's a better pic to show where it's at in the stove room
    In relation to that pic the register booster upstairs is about 10 feet back towards the middle of the room along the wall so it stays in the same joist chase. The floor/ceiling joists run from behind me in that pic toward the stove.
    cnice_37 likes this.
  12. Trilifter7
    Trilifter7
    Waynesville, OH
    My stove room is directly below our master bedroom as well. I noticed no difference in noise from down stairs to up. I think having them offset helped that a lot. If anything the fan in the bedroom was nice bc it droned out any other noises in the house and was somewhat soothing to sleep to.
  13. cnice_37
    cnice_37
    Nice digs man, I like the wood holder - fits right in with the decor.
    Trilifter7 likes this.
  14. Trilifter7
    Trilifter7
    Waynesville, OH
    Thanks cnice! We just moved in last year so we are still getting things settled. Next project is putting a stone wall up behind the stove. I'll post some pics when I do it.
  15. eatonpcat
    x2 on the nice place!!
  16. Trilifter7
    Trilifter7
    Waynesville, OH
    Thanks Eaton! I group up in Brookville OH, is that close to the Eaton you're from?
  17. bogydave
    Good idea !
  18. eatonpcat
    Brookville is about 3.5 hours south west of Eaton Township. I'm south west of Cleveland, Brookville is around Dayton, OH.
  19. Trilifter7
    Trilifter7
    Waynesville, OH
    Gotcha, there's an Eaton, Ohio that's about 20 min west of Brookville so wasn't sure if it was the same one.
    eatonpcat likes this.
