Glass Cleaner
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ttdberg, Nov 5, 2014.
  1. ttdberg
    ttdberg Pellet Pig
    CT
    Until this year I had always used windex or something similar to clean the glass on the stove. I saw this stuff at the store and decided what the heck. What a great find this was! It's a light blue color and has the consistency of tooth paste. Holy cow it works very well, even the dark brown caramel-like deposits that form on the glass that are traditionally very hard to clean off, come off like butter with this stuff. Highly recommend it!
  2. HDRock
    I use this, bought it at Home Depot works very goood
    Magic Glass Cooktop Cream and Polish
    raybonz and NYCountry like this.
  3. NYCountry
    NYCountry
    Mohegan Lake NY
    I usually use vinegar and it works well
    savemoney likes this.
  4. CoachSchaller
    CoachSchaller
    Southeast Michigan
    It also puts a barrier on the glass to keep it cleaner longer. And it works well on my glass stovetop.
    HDRock and My IS heats my home like this.
  5. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I either use ash from the stove and water which works miracles or rutland stove cleaner which melts the grim off.
    HDRock likes this.
  6. imacman
    imacman
    Denver, NC
    A wet paper towel dipped in stove ash is all I ever used.....works great and is basically free.
  7. My IS heats my home
    My IS heats my home
    Albany, NH
    Great tip ttdberg , I'll give it a look.
  8. subsailor
    subsailor
    Winthrop, Maine
    I've been using the Rutland Glass Cleaner for years. It removes everything.
  9. savemoney
    All I ever use. Go over it a second time with just a slightly damp towel to. Get the film off. The microfiber ones work best.
    mepellet and imacman like this.
  10. eatonpcat
    I use the Rutland on occasion, but usually just use a wet paper towel.
    will711 likes this.
  11. will711
    will711
    Pocono Mts.
    That's what I do too
    mepellet and eatonpcat like this.
  12. jtakeman
    I use the wet rag too. If I get a stain, I usually dip the rag into the ash first. Then finish with a clean wet rag.
    One brand of Oak pellets left a stick stain. I used a bit of goo be gone on the sticky spot. Seemed to work well.
  13. Birddog91
    Birddog91
    Lakes Region NH/Connecticut
    Love the ash idea, I use wet paper towel. Was told never to use windex etc... .
    jtakeman likes this.
  14. jtakeman
    I killed my first glass seal with windex on my old Quad. The windex seemed to work at the seal fibers and I had a bunch of strings hanging from it.
    Birddog91 likes this.
  15. PoolguyinCT
    PoolguyinCT
    I killed my first 3 gaskets with the blue stuff. The dealer recommends it & uses it in the showroom.
    Birddog91 and jtakeman like this.
  16. KatwillNY
    KatwillNY
    I like most things Rutland, although I agree with Pete, damp paper towel and ash works well on both my pellet and wood stoves.
  17. Lousyweather
    Lousyweather
    all good, just don't use it on the outside if you have mirrored glass (many Harman units now)
  18. subsailor
    subsailor
    Winthrop, Maine
    The Rutland or the ash?
  19. Lousyweather
    Lousyweather
    either one
  20. Iron Stove
    Iron Stove
    Central CT
    I alternate the Rutland, and wet towels. Really helps prevent any burnt up crud from bonding to the glass.
