Stove pipe question.
Discussion in 'Modern EPA Stoves and Fireplaces' started by Drvn4wood, Oct 26, 2014.
  1. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I have a stainless pipe coming out of the stove and it has discolored quite a bit near the the connection with the stove. I have hit it with an ir gun and never seen anything over 675. I've worked with a lot of stainless in the past and know it's prone to discolor with heat but this looks like crap now. The inside is very clean as far up as I can see. Anyone ever had one? I got the pipe for next to free because someone ordered it but didn't want it. Thoughts? The lighting makes it look worse than it is. The lighter spots near the bottom are a better representation than the really dark side. 1414362959384.jpg
    Pallet Pete likes this.
  2. nate
    nate Banned
    Palmer, AK
    Scuff it up, shoot it with some Stove Bright flat black to match the stove. That is what I did to mine.
    Drvn4wood likes this.
  3. MightyWhitey
    MightyWhitey
    Harley exhaust pipes do the same out of the head. Nothing to worry about.
  4. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Thank you nate and mightywhitey. That's what I thought and what I will do..
    Thanks again..
  5. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Your perfectly fine. Stainless chimneys do that at the tip due to the heat as well.
    Drvn4wood and MightyWhitey like this.
  6. papadave
    675 on the outside of insulated double wall?
    That's an overheat if true.
    concretegrazer likes this.
  7. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    No. Single wall with an ir gun.
  8. concretegrazer
    concretegrazer
    Southwest MO
    Unless you're using a highend ir the temps you're getting off stainless probably are unreliable due to the emissivity calibration. And 675 on single wall is roughly 1350 internal which is too hot for my taste.:coffee::bug:
  9. Machria
    Machria
    Long Island, NY
    I just installed the same type (stainless) of pipe. I painted it with Stove Bright Satin Black paint, dries in 10 minutes and matches most stoves... If you scratch it (which is easy to do!), just spray the spot again, and it disappears as soon as the paint dries...
    Backwoods Savage and Drvn4wood like this.
  10. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I will be doing that.. Did you scratch it with stainless wool first or just shoot it?
  11. Machria
    Machria
    Long Island, NY
    I had my pipe custom made since I had some odd angles, so they painted it black for me. It did not look like they had "buffed" it prior to spraying it. And it showed becauase the paint scratches off real easy, too easy. After I was done installing it, it was scratched all over so I just hit it with the Stove Bright, cleaned it right up.
    But if I were to it from scratch (no pun intended!), I would buff it a bit with steal wool or something.
