New Englanders and Electric Rates
Discussion in 'Everything Else (off topic)' started by Spock, Oct 24, 2014.
  1. Spock
    Spock
    MA
    wildwest, raybonz and papadave like this.
  2. IHATEPROPANE
    IHATEPROPANE
    We have more Nat Gas than we know what to do with in this country but my wonderful state of Massachusetts will not expand pipeline capacity.........that is all I am going to say.
    wildwest, Jack Straw and Spock like this.
  3. lukem
    Makes my $.0925 look pretty good.
  4. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    Michigan is paying $0.1091 Not too shabby, guess it might be time for you to move to LED lighting and start shutting off all the little vampires, phone chargers, cable box, dvr, router, cable modem. Im starting to do all of this and I am down to about a $30-$40/month bill. has taken a while to get there though.
  5. Spock
    Spock
    MA
    I am paying $0.27 if you add the generation charge plus all the delivery charges and other line items not associated with the generation rate. A few years back MA started penalizing you if the electric usage went over 1000kwh for the month. For me that surcharge was another $30 a month...that's when i installed a pellet stove and turned off the electric baseboard cash registers.
  6. MightyWhitey
    MightyWhitey
    I'm as niggardly as they come. My bills run about the same as yours here in northeastern "The Peoples Republic of Illinois.
    Breaking down my bill: I spend more on the "privilege" of being hooked up to them than I do for the amount of electricity that I use!!!!:rolleyes:
    splitoak, wildwest and Spock like this.
  7. Spock
    Spock
    MA
    Already there! The only have 4 small incandescent left in the light fixture above the kitchen table. Still have yet to find the small 40w led appliance bulbs that throw light down when installed upside down.
  8. jharkin
    jharkin
    Im glad Im on NSTAR.... They always tend to have lower rates than NatGrid... and few outages in big storms as well.
    For those of you on NatGrid, you should be able to take advantage of one of the competetive suppliers to avoid this hike if you want.
    Also, read the article more closely. Its is double "last winters" rate but only 37% more than the current rate (remember both NG and NStar raised rates a little last spring) and this is only the generation portion. So you bill is not actually going to double. Its likely to go up about 20% overall vs this month on a per kilowatt basis, considering transmission charges make up about half the bill.
  9. jharkin
    jharkin
    This must be your utility, its not the state. Im on NSTAR and I dont get any penalty for going over 1000 KWh (we often go well over with AC). My rate runs about 18 cents all up - 9 cents for power and 9 cents for transmission and taxes.
  10. Spock
    Spock
    MA
    I called WMECO about it. They told me it wasn't them it was the State and there was nothing they could do except provide a free audit and some discounts on lights and house upgrade (windows , insulation) which I had already done. Confused.:confused: But it might be that NSTAR is a TX based company WMECO is based in MA.
  11. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    Detroit Edison Electric (most of SE Michigan ) pays $.05 something for generation and $.05 something for distribution for the first 17kw per day. Then it goes up. then there is some kind of charge monthly for being hooked up to the grid, something like $6.00 for residential.
  12. jharkin
    jharkin
    Interesting... how is it itemized on your bill? Id like to cross check mine.
    I DO have a line item for energy conservation under the distribution charges but it amounted to a whopping $2.50 on last months 1,040 kWh billing.
  13. raybonz
    raybonz Moderator
    Carver, Mass.
    Interesting.. I heard about the National Grid thing and as bad as Nstar is it is far better to be with them.. I feel all power should be municipal as you can't shop around for power.. I wonder if I'd qualify for solar here? Where in Mass. are you located?
    Ray
    Spock and wildwest like this.
  14. IHATEPROPANE
    IHATEPROPANE
    My bill this month is $108 for 670kW.
    Spock, wildwest and raybonz like this.
  15. 343amc
    343amc
    Northeast Lower Michigan
    I pay roughly .135 at home and about .165 per kWh up north when all is said and done. At my shack up north I pay $17 a month just to have the meter hanging on the building. The meter fee there is usually about double what my usage is.
    wildwest, Spock and raybonz like this.
  16. Spock
    Spock
    MA
    I dug up a bill from February 2012. This is the last billing before the stove was up and running. The surcharge is more than I remember but I might have been thinking of a bill prior to this.
  17. Spock
    Spock
    MA
    SW mass. There were some rebates available from both the State and Federal. Don't recall how much though. Quick Google should get you up to speed.
  18. wildwest
    No where near NE.... $0.1136 and $45 service fee.
    Spock likes this.
  19. nate
    nate Banned
    Palmer, AK
    I'd pass out seeing those bills. Use 100-200 Kwhr here on average. Summer is negative use. Make more power than used. My last bill was -26.50.
  20. IHATEPROPANE
    IHATEPROPANE
    How much did your set up cost? And could you provide details for us?
    Spock and MightyWhitey like this.
