Newbie... Need Install Advice For Farenheit Endurance
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Triple A Arsenal, Sep 25, 2014.
  1. ivanhoe
    ivanhoe
    Northern Ontario
    X2 DTM for flexibility. OUCH$$$$$$ but will soon forget and enjoy the benefits later.
    DexterDay likes this.
  2. 343amc
    343amc
    Northeast Lower Michigan
    I'm kinda kicking myself in the rear for not going with multitfuel when I put mine in. I had some venting that came with it that I used and wanted to stick with the same brand, so I went with Selkirk VP. Hindsight being 20/20 I wish I'd gone with multi fuel.
    If pellet prices ever fly through the roof and corn/pits/fossilized rabbit poop gets cheap, I may swap the venting out. Time will tell.
    jtakeman, eatonpcat and DexterDay like this.
  3. jtakeman
    I got a big pile saved for ya! ;)
  4. mithesaint
    mithesaint
    NW Ohio
    I paid $125/ton of corn at the local elevator earlier this fall....
    jtakeman likes this.
  5. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    The 6" bracket goes on the 4" pipe?
  6. 343amc
    343amc
    :( That's cheaper than it is here. Last I knew it was about $165/ton around here. Still cheaper than pellets, but bulk storage is my main issue.
  7. DexterDay
    No. I bought both brackets. I only used the 4" bracket on the Clean out T (the very beginning is just 4" vent) After the T it transitions into the 6" vent with OAK outlet.
    Maybe a pic would help? (Dusty back there :()
    schoondog likes this.
  8. mithesaint
    mithesaint
    NW Ohio
    Yeah, at $125/ton I was willing to give it a try. If the price was closer to pellets maybe not, by the time you take into account the bulk issues. I borrowed a gravity wagon from my neighbor, bought some corn from the elevator, and I have it stored in barrels and trash cans in my basement. I even had a nice little contraption made up to funnel it through a basement window into the barrels, but it didn't hold up well enough. Had to carry quite a few 5 gallon buckets down the stairs.
  9. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Trying to find Selkirk DT-M venting is :hair:
    You guys that are using DT-M.......where did you get it from and how much?
  10. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Was that for the 4" or 3"?
    Looks like the 3", the endurance calls for 4"
  11. smoke show
    smoke show
    Pittsfield, Wi
    4". What about the amazon link I posted earlier?
  12. DexterDay
    All of the DT is 4"? I thought?
    It can start as 3", but goes up to 4" at the T. Or if your stove has a 4" outlet, then you can run 4" all the way. But the Fahrenheit has a 3". So you need the 3" appliance adapter, then the 4" increaser, and 4" for the rest of the system.
  13. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    That's a 4" kit but it DT not DT-M
  14. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    They make DT-M in 3" kits which are lots cheaper than 4".
  15. DexterDay
    Yeah, the M is more expensive. Looks to be a lot more expensive. Whatever you do, stick with 4". Your insurance agent won't like the 3", nor will the inspector (if you need an inspection).
    I only got DT for my Enerzone because it is only a pellet stove (but will burn other high ash pellets/switchgrass, etc). If I ever want to burn a cheaper biomass, it will be in the Fahrenheit that has Multi fuel rated vent (Pellet vent pro).
  16. smoke show
    smoke show
    Pittsfield, Wi
    Yes i seem to remember they make 3/5 and 4/6. I guess if you wanna play you gotta pay... go big or go home. ;)
  17. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Hahaha it's so true!:drool:
    I think I read the DT can do pellets and corn...is that true?
  18. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Is that the Simpson multifuel kit #33100? I was looking at that for $380
  19. smoke show
    smoke show
    Pittsfield, Wi
  20. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Yeah I just read that, lots of company's selling products and giving false info.
    I did see the Duravent 4" multifuel kit for $380
    Downside is more labor installing the OAK
