How I measure rounds to length
Discussion in 'The Wood Pile' started by bogydave, Nov 5, 2013.
  1. bogydave
    I use a piece of an old graphite fishing pole
    Glued a 1/4 - 20 headless bolt in one end & attached it to the bar with a wing nut.
    Have a 17" one for my stove (+ a 16 " in case I cut for someone else).
    Mark the log before I cut it to sizes I can skid out to the truck/trailer
    Uniform length & no short rounds of the end of logs.
    If I can get the log off the ground, I just leave it on & cut 15" & smaller rounds.:
    U-TUBE : Video
  2. USMC80
    USMC80
    thats awesome, what do you have on the end of the rod?
  3. Hinerman
    Hinerman
    NE Oklahoma
    Nice,,,very resourceful. I just use dalrods; I have 3 (16, 18, & 20 inches). I mark the wood with a yellow wood marker and cut. Takes a little more time than your method though unless I have my son with me----he marks, I cut.
    T.Jeff Veal and Stephiedoll like this.
  4. reckless
    reckless
    I just know the lengths of my bar, to the dawgs is 18" to the body is 20" :) But your technique would save a little time not having to put the saw on the log, cool idea!
    KsKent likes this.
  5. capetownkg
    capetownkg
    southern, MD
    I like that system bogeydave. Could have used it this weekend. I cut a couple pieces long.
  6. Blue2ndaries
    Blue2ndaries
    Oregon
    Nice setup Dave. I made a simple 24in stick with colored markings for 18, 20in viewable from either side with a handle in the middle. My boys enjoy using sidewalk chalk to mark lengths along the trunks for me to cut. I typically cut to 18inches.
  7. BillinTX
    BillinTX
    Northeast TX
    I have limited depth perception so cutting by sight is not an option for me.
    I have tried and still use all the different types of markers.
    I cut my wood 18" to 20", that's the size that works best for me.
    I have multiple sticks marked 18" and 20".
    I marked the side of my saws.
    I even marked the cross braces on my sawbuck.
    I made a pvc tap-a-log that uses carpenters chalk.
    I made 4 different fishing rod markers.
    2 with hard drive magnets and 2 that are spring mounted to bar nuts.
    The one that works best for me and is the fastest to use is the spring mounted ones.
  8. bogydave
    Sweet !
    My next one will have the antenna spring :)
  9. HDRock
    Here is my whip antenna , it has a set screw for adjustable length , I cut to17"
    Started out with a wing nut ,then changed it to a magnet
    Saw Marker.jpg IMG_20130414_151943.jpg IMG_20130414_152010.jpg IMG_20130414_152128.jpg
  10. bogydave
    Spring & magnet are upgrades.:thumbs:
    New model I copy the ideas.
    Drvn4wood, Ralphie Boy and raybonz like this.
  11. Blue2ndaries
    Blue2ndaries
    Oregon
    Ditto...I like the magnets and springs....
  12. bogydave
    New one with strong magnets.
    [​IMG][​IMG][​IMG][​IMG]
  13. Gark
    Gark
    SW Michigan
    The rule of diminishing accuracy:
    1. Measure it with a micrometer.
    2. Mark it with chalk.
    3. Cut it with a hatchet.
    I just use an 18" stick and kid's sidewalk chalk. Close enough.
    GrJfer, EnglishBob, tamarack and 2 others like this.
  14. rayvil
    rayvil
    Maryland
    I use the Mingo Marker that Bailey's sells. (I'd post a link, but don't know if that's allowed.) It works pretty well and a can of spray paint will last a season. Been using it for at least four years now with no complaints.
    BetterCallMaul and bobdog2o02 like this.
  15. Backwoods Savage
    I go for high tech. One of these and a 16" long stick.
  16. Machria
    Machria
    Long Island, NY
    Cool idea with the rod attached to the bar. But I would have to remove it 90 out of 100 times.
    I'm surprised you all are talking about a single cut length for measuring and marking?? I buck at either 18" or 20". For the 18", I have a 6' long 1 x 2 piece of wood I painted bright orange, and I marked it at 18", 36", 54" and the other end is 72" with a big bold black line. I simply lay the piece of wood on the tree, and mark the tree with a piece of chalk at each mark (4 marks). I can then slide it down to the last mark and repeat, takes 20 seconds to mark a 30' tree. Now you can cut the entire tree without measuring or marking anything, just cut on the chalk marks....
    Timberdog and mikeward like this.
  17. Gasifier
    Ya. Starting out with a wing nut has been known to lead to problems HD.
    HDRock likes this.
  18. bogydave
    I've used several methods to measure
    This one works best for me. strong earth magnet.
    1 tool, easy, fast, accurate , small to carry in/to the woods, fits in my pocket
    Walk the log & mark, pull it off & start cutting
    WinonaRail, NYCountry, HDRock and 2 others like this.
  19. Gasifier
    Where do you buy the earth magnet? How is it attached to length of rod?
  20. bogydave
