NT Sharpener on sale again
Discussion in 'Chainsaws and Power Equipment' started by Jutt, Oct 3, 2014.
  1. HDRock
    You won't lose your man card if you read the manuals and watch some YouTube videos :D
    clemsonfor, Chvymn99 and Gary_602z like this.
  2. Hedgerow
    Hedgerow
    SW Missouri
    I got my NT grinder and installed it on the bench...
    For the money, it's a fantastic grinder..
    I made some modifications, and tightened all the loose items up...
    The light is awesome...
    Just sayin..
    Next mod??
    Reverse switch..
  3. Chvymn99
    Can you take pictures of those modifications... Please...:yes:
    DexterDay and HDRock like this.
  4. clemsonfor
    Ordered one and will pick up next time we go to see the inlaws as they have a store in their town. Saves me the $15 shipping.
    Thanks for the lost I have been wanting this one..esp since everyone says its so good . Also cause it does raker!
  5. HDRock
    Yeah, me being a novice would like to see what mods can be made to make it better
    clemsonfor, DexterDay and Chvymn99 like this.
  6. Hedgerow
    Hedgerow
    SW Missouri
    Extra washers on the chain clamp to keep the groove "less open".. Chain was wanting to drop into the groove..
    Also on the indexing pawl.. It was a little sloppy, so I put an extra spacer behind it also, took up the play..
  7. Hedgerow
    Hedgerow
    SW Missouri
    I tried to reverse the motor tonight...
    No luck...
    But I will find a way...
    Chvymn99 and HDRock like this.
  8. clemsonfor
    And why would you want to reverse the motor? Just curious....my little mind can't understand why?
    The modifications I totally understand but not the motor reversal?
    HDRock likes this.
  9. Chvymn99
    Yep, did that on the rail after reading a thread from Lukem I believe. I know what your talking about on the paw, I'll have to throw one in there too. As far as motor reverse...:popcorn: too bad its not like a three phase systems just switch one set of legs around...
  10. DexterDay
    Because on one set of cutters, it puts the burr inside (correct), and the other set of cutters is on the outside (wrong).
    With a reversible motor, you are able to have both sets of cutters, with the burr inside.
    Hedgerow, clemsonfor and Chvymn99 like this.
  11. clemsonfor
    Makes sense. So what about handfileing. Thats done inside out.... But I dont remember a but fileing like you get with the grinder.
  12. Moparmyway
    Moparmyway
    New York
    If its the same as the 511a .............. this is a real easy one
  13. Moparmyway
    Moparmyway
    New York
    I now file outside in ............... all the time, every time. Cutters get sharper and stay sharper longer
    Chvymn99, Hedgerow and clemsonfor like this.
  14. clemsonfor
    I want to learn to file like that square file in your avatar :drool::banana:
  15. Hedgerow
    Hedgerow
    SW Missouri
    Yup... All teeth sharpened the same will make a better cutting, longer lasting chain...
    Still not as fast as a file sharpened chain, but close....
    And very useable...
    Moparmyway and Chvymn99 like this.
  16. Moparmyway
    Moparmyway
    New York
    That was my very first whole chain that I filed, and since then, I have made some different adjustments to my file position, the cutter position, and the gullet. You can learn to square file, it might take a little practice, but you can do it !
    Hedgerow, DexterDay and clemsonfor like this.
  17. Chvymn99
    I see that Northern Tool has them for $79.99 w/ coupon from 11/29 to 12/13
    HDRock and MasterMech like this.
  18. clemsonfor
    Dang it. Thats a bit better than I did :-(
    I paid like $83 cause I had to buy something to get the price over $100 to get the extra $20 off.
  19. cutforfun
    cutforfun
    I just checked and they say 119.00???
  20. clemsonfor
    Sounds like you need a coupon code?
