Husqvarna score
Discussion in 'Chainsaws and Power Equipment' started by cutforfun, Oct 12, 2014.
  1. bogydave
    Super score for $60 & some gas.
    How many you think you'll have running by Christmas ? :)
    DexterDay likes this.
  2. cutforfun
    cutforfun
    I will let you know , nothing headed to trading post yet. I need to figure out what I need . I do have a full wrap and a standard for a husvqvarna 362 that I won't be needing.
    mdavlee likes this.
  3. cutforfun
    cutforfun
    :pfree gas, work pays for it. Should be able to make a few runners by thanksgiving
    concretegrazer and cnice_37 like this.
  4. NH_Wood
    NH_Wood
    Holy crap - that's a great score all right - good for you!!!! Cheers!
  5. mdavlee
    mdavlee
    Thanks. I just need a few small parts. I may get the wrap handle for the 362 for my 372.
  6. cutforfun
    cutforfun
    I said 362 but I think the misc handle bars are for a 562. I will get some pics later. I may have a 372 full wrap :yes:
    mdavlee, DexterDay and Chvymn99 like this.
  7. cutforfun
    cutforfun
    Pulled the slug and jug from the 385 and threw it in the 390, fired right up. :cheers:
    Also found a tank of straight gas in the 390:headbang:. Did not run long the cylinder should clean up fine and I will get a piston for it.
    IMG_20141013_211954762.jpg IMG_20141013_211941144_HDR.jpg IMG_20141013_211855260.jpg
    FredRed, cnice_37, DexterDay and 2 others like this.
  8. cnice_37
    cnice_37
    So..... you wanna double your money?!
    That is a clean 390/385 too.
  9. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Saw Troll commented somewhere that the stock porting scheme on the 385 jug is much better than that of the 390. Myself I don't have any proof.
  10. cnice_37
    cnice_37
    OK, the, ahem, well fed, orange chick on the side of the bench is great! :cheers:
    MasterMech and cutforfun like this.
  11. mdavlee
    mdavlee
    There's a decent difference in port timing numbers. I tested stock to stock and they were even. I wouldn't doubt a 385 would end up faster than a 390.
    cutforfun likes this.
  12. cutforfun
    cutforfun
    Is there room to pull the base gasket? I will verify squash, but if every body says no I won't try.
  13. mdavlee
    mdavlee
    It depends. I've seen them both ways with squish from .027-.042".
  14. cutforfun
    cutforfun
    Thanks that's what I needed to know. I will go threw the trouble if I know it may work.
    mdavlee likes this.
  15. Gasifier
    Wow. Nice score there cutforfun!
