Trouble in hoarders land
Discussion in 'The Wood Pile' started by Unicorn1, Oct 11, 2014.
  1. Unicorn1
    Unicorn1
    Amarillo, TX
    Another shop is going up this month across from mine, I lease the shop/land. The electrician stated the power lines which run underground behind my shop would go around my wood piles, across the field to the new shop.:) Well today I talked to the land owner and the engineer stated the underground lines would be ran directly beside my shop where all the wood piles are.:(:( Waiting for the final word, if all the wood needs to move come on out to Texas and my wife will cook steak and briskets..:)
  2. nate
    nate Banned
    Palmer, AK
    Sounds like the guy building the new shop has some work cut out if he wants power. If I was in that boat I'd say tough chit, I'm not moving anything!
  3. jetjr
    jetjr
    Pa/Md line
    I would think you have some say in that. Talk with the engineer themselves it is your property after all that they want access to.
    Shawn Curry likes this.
  4. Unicorn1
    Unicorn1
    Amarillo, TX
    I lease the shop/land and the owner is a great guy, he knows he will have to move it all himself if I'm out of town on D-Day. The new shop slab is in place just waiting for the steel.
    Backwoods Savage and Shawn Curry like this.
  5. bogydave
    Directional drilling an option ?
  6. Thoreau's cabin
    Thoreau's cabin
    Vandalia, Ohio
    Agree. They should be able to go under that no problem.
  7. Unicorn1
    Unicorn1
    Amarillo, TX
    Sounds like a 5 ft deep trench is going in.
  8. Backwoods Savage
    That seems a bit odd going that deep. Must be a reason.
  9. Unicorn1
    Unicorn1
    Amarillo, TX
    Here's the black electrical conduit, looking north. I moved most of the wood out that was along this side.
  10. Unicorn1
    Unicorn1
    Amarillo, TX
    Maybe this is a sign for me to grade this area flat once and for all, after I move all the wood.:(
  11. Unicorn1
    Unicorn1
    Amarillo, TX
    No answer to where the trench is going so I'm moving wood as a preemptive measure. I have to go back to Albq, NM to work for a few days so we'll see what's happened when I get back.
  12. chris
    that install won't pass code around here
  13. Unicorn1
    Unicorn1
    Amarillo, TX
    ???, the conduit is the electric run already in place for the future shops on the property. All the future yellow gas line and black electric line are sticking up out of the ground?
  14. chris
    I see a black plastic electric line coming out of the ground traveling several feet exposed then entering the building- won't pass code here. At the very least that would have to be framed in in some sort of anchored chase or buried and not exposed until very close to slab and the a small chase anchored to cover the exposure. Rules vary in different areas.
  15. Unicorn1
    Unicorn1
    Amarillo, TX
    The black conduit in the pics is just excess that's touching my shop outside wall, zero connection.:)
    dylskee likes this.
  16. chris
    Looks can be deceiving, sorry for the rant.
  17. Unicorn1
    Unicorn1
    Amarillo, TX
    It's all good.
  18. Razo
    Razo
    Pennsylvania
    I thought it was coming out of the wall too haha...that's what ya call one of them there optical illusions.
  19. Unicorn1
    Unicorn1
    Amarillo, TX
    Good pic. I did unearth this gas line but it turned out to be a scrap piece that didn't make it to the trash.
  20. Certified106
    Certified106
    In The Hills
    Well that stinks at you had to move all that wood......
    dylskee likes this.
