  1. lukem
    Weather here is all over the board. Was 30 yesterday morning....low tomorrow night is 50. High of 62 today and high of 49 Thursday. I can't get into any kind of burning routine.
    50's/30's is where I really struggle heating with wood...either too hot or too cold in the house depending on whether or not a fire is lit. Right now it is too warm to have a fire and too cold not to have a fire.
  2. papadave
    Forgot to mention it was 30 this a.m., and plenty of Maple coals left to reastart. 67 in the house too.
    However, I had 8-9 splits in the stove last night @ 11-ish.
    jmb6420, NortheastAl and WeldrDave like this.
  3. Chvymn99
    Jon,
    Stick around and you'll learn ALOT. Insulation and stopping the drafts are and will definitely help your heat output stay where it should be inside. Using a fan & blowing the cold air to the warmer area. Dry wood...
    FatBoy85, jmb6420, milleo and 3 others like this.
  4. Chvymn99
    We were in the middle 40's this morn. Had no fire lastnight, it was still fairly warm in the house. But this morning, I cranked her up so I get back in my short and out of the long johns & sweatpants....
    jmb6420, NortheastAl and Gasifier like this.
  5. MrWhoopee
    MrWhoopee
    Shingletown, CA
    35 this morning. 2 medium-large splits of lodgepole in the stove last night, intake closed, woke up too warm at 2:00. Plenty of coals this morning for the restart. Snow forecast for next week. :D
    jmb6420 likes this.
  6. Jon1270
    Jon1270
    Pittsburgh, PA
    Oh I know, things are better this year than last because I've got a supply of decently dry wood and am using a fan to help with circulation. It's great to be able to build (or build up) a fire quickly and predictably because the fuel is so much better. Even so, most of the house is a little cool for my taste, even though I like it cool.
    I have no problem keeping the stove temps up, but less of that heat than I'd hope seems to get kicked out into the room. I still need to improve the insulation around the insert behind the surround because the old firebox around the insert is steel and vented through the chimney to the sky, so it's unusually capable of soaking up heat that escapes the air jacket. I suspect my arrangement's currently-disappointing performance can mostly be chalked up to that, along with the lackluster attic insulation. The windows in my house are already pretty decent. I suspect the thing to do is make some changes and see what happens.
    jmb6420 and Chvymn99 like this.
  7. USMC80
    USMC80
    26 last night 3/4 load of sass at 2230, house at 74 f and stove at 380 f at 0630
    jmb6420 and NortheastAl like this.
  8. Jon1270
    Jon1270
    Pittsburgh, PA
    Wow, 380F after 8 hours is pretty good, especially on sassafras. I take it this is a cat stove?
    jmb6420 likes this.
  9. USMC80
    USMC80
    Negative. Hampton HI300. With temps in the 30s I easily get 10 hours of useable heat. Gotten up to 14 hours with the fan still blowing and easy relight. Heating about 1200 sq ft, 15ft chimney. Haven't burned a load of oak yet as thats stacked for next winter
    jmb6420 likes this.
  10. Jon1270
    Jon1270
    Pittsburgh, PA
    Impressive.
    jmb6420 likes this.
  11. Blue2ndaries
    Blue2ndaries
    Oregon
    We've had a few frosty mornings w/highs in the low to mid 50s. Been burning shoulder season stuff along w/a few oak uglies in the evenings and overnight to keep it nice and toasty in the house at 75-77deg. My modus operandi during the winter is to be in shorts/t-shirt when I'm inside. :D
  12. bogydave
    30° last night, 36° now (burning birch)
    To be in the 20s starting Tuesday night. (will burn birch)
    Was burning birch last month
    Was burning birch last week
    Am burning birch this week
    Am burning birch today
    Will be burning birch next week
    Will be burning birch next Month
    :zip:
    jmb6420, Got Wood?, milleo and 5 others like this.
  13. Blue2ndaries
    Blue2ndaries
    Oregon
    Sounds like "life's a birch" Dave... :D
    jmb6420, milleo, HDRock and 4 others like this.
  14. bogydave
    I have a birch'n woodshed & stack :thumbs:
  15. papadave
    I'm curious where stove temps peak for you guys.
    I can get a decent 8hr. burn (at least), but after an hour or so into the burn, it can get too warm because the stove runs too hot. Not overfire too hot, just too hot for needs.
  16. papadave
    I see what you guys did there.
    jmb6420 likes this.
  17. rottiman
    20's @ night 30's daytime. Soft maple and some blow down pine branches from last winters ice capades. I'm like Blue2econdaries re temp. So far so good
    jmb6420 likes this.
  18. MrWhoopee
    MrWhoopee
    Shingletown, CA
    I have the same problem, by the time I get the secondaries to fire, it's time to knock down a wall. And, of course, once it gets to that point you can't just turn it off. I've given up, I've got an EPA smoke dragon.
    jmb6420 likes this.
  19. basod
    basod
    Mount Cheaha AL
    36 overnight and I think it hit 62 today - burning a bag of sweetgum then a few splits of red oak before bed - 74 in here this morning and a small reload to keep the house warm until the sun came over the mountain. Getting ready to light off again soon love running around in my skivies:thumbs:
    jmb6420 likes this.
  20. SolarandWood
    SolarandWood
    Syracuse NY
    Wouldn't it be nice if someone came up with a big firebox stove that you could load full every time and forget about it whether it was October or January? Maybe one that you didn't even bother keeping a thermometer on?
    jmb6420 and bogydave like this.
