Shipping Container/Conex Box/Storage Bin Build
Discussion in 'The DIY Room' started by Jeffrey Svoboda, Nov 18, 2026.
  1. Jeffrey Svoboda
    Jeffrey Svoboda
    Come to find out, this container was in a little rougher shape than I would've liked. I suppose that's what you get buying site unseen. I explained to the guy what I was going to do with it but obviously that didn't matter to him. Lesson learned.
    This thing had all kinda dents in the roof. With the floor jack and a heavy piece of timber I starting pushing the dents out from the inside. Took more than a day to get it acceptable. Along the way I found a small pin hole where sea water must've sat for years.
    I got up on the roof and scraped and wire brushed the bad spots. Got some rust converter paint and painted it like it should've been before I bought it. Didn't get any pictures of the end product but just imagine big ol black spots on an otherwise grey roof.
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    Now the roof joists connect to that 2x that was screwed and glued to the top tube. I could rough frame in where I wanted the "front" 3 windows and entry door. As for the other 3 windows, the framing got cut and knocked off the walls once I decided final placement. Which was after the first 3 windows got set in place.
    Onto cutting a hole for the entry door. At this point I didn't know what kinda gap I wanted between the door frame and metal wall. So I was kinda nervous drilling/cutting a hole in the side of my container. I knew it had to be done so onward I pushed. Marked and drilled holes from the inside.
    Then connected the dots on the outside so that I could cut from the outside. Cut the opening a little small and worked it out to where I liked.
    Installed the frame.
    And the slab.
  3. Jeffrey Svoboda
    Jeffrey Svoboda
    I forgot the mention packing the front corners with foam insulation before covering them.
  4. Jeffrey Svoboda
    Jeffrey Svoboda
    Well after the first big hole the nervousness somewhat subsided. Onward and upward with making a couple more. I don't think I cut one of the window holes that didn't need buffing to final size but that last window sure didn't need much.
    After cutting this one I learned to try and straighten the walls before cutting the hole. This one warped almost 2 inches in the middle. This was my attempt to fasten it without screws. Needless to say there are screws under all the big windows.
    After getting 2 of the end windows in I could decide where to put another window.
  5. metalcuttr
    metalcuttr
    western WA
    Those windows will definitely contribute to an open and airy feel!
  6. Jeffrey Svoboda
    Jeffrey Svoboda
    I sure hope. I forgot to mention the sizes. At the very end I bolted two 3' wide x 4' tall windows together. The other two on either side of that one are 4'x4' and the smaller ones I wasn't sure on the mounting location are 4' wide x 2' tall.
  7. Jeffrey Svoboda
    Jeffrey Svoboda
    Looks like I got a bit of the divider wall put up before doing the last big window.
    Here's the bedroom.
    Here's what it looked like from outside at that time.
  8. MikeInMa
    Looking like an abode to me!
    Good continued luck!
  9. JimBear
    JimBear
    When I worked in the Bakker Oil patch, we had a 20’ conex box that was used for sleeping quarters. Added a walk-in side door & just built 2x4 frame shelves in it as well.
  10. JimBear
    JimBear
    Some JB weld will fix that right up
  11. Woodwidow
    I am really enjoying the pictures of the renovation. What a lot of work.
  12. Jeffrey Svoboda
    Jeffrey Svoboda
    Thanks! It's definitely more work than I imagined but it's coming out better than I imagined also.
  13. Jeffrey Svoboda
    Jeffrey Svoboda
    After the last big window was installed I could decide where I wanted the final window in the "living room". I wanted to be about to see out of it while sitting down. It's kinda weird cause I gotta bend down, while standing, to see outta it but I think I'll like it once I get a couch in there.
    Very blessed to be able to work on blacktop right next to the container.
  14. Jeffrey Svoboda
    Jeffrey Svoboda
    I built out the rest of the divider walls but didn't take any pictures. After that came subfloor. The entry door wasn't permanently installed until after the subfloor that way it could sit on top of the subfloor. If you look closely you can see it sealed with green tape.
    1" of polyiso insulation under 3/4" and 1/2" subfloor. The 1/2" gets 1/4" of cement board for tile install. This allows the finish floors to be the same height with minimal shimming.
    As you can see here, the floor helps lock the studs in place also.
  15. brenndatomu
    What will the finished height be inside?
  16. Jeffrey Svoboda
    Jeffrey Svoboda
    Too short for you! :p
    Seriously though, I don't remember the exact number. I'm thinking it'll be about 7'4" but I'll put a tape on it and post the actual number.
  17. Jeffrey Svoboda
    Jeffrey Svoboda
    brenndatomu looks like I was wrong. :(
    With the finished floor it'll be 7'4"+1/4" :D
  18. brenndatomu
    Well shoot...I'll be able to stand up straight and maybe even kinda sorta stretch...as long as I don't wear cowboy boots! :whistle: ;) :rofl: :lol:
    Plenty of room...just gonna limit your ceiling fan choices a bit! :eek: :rofl: :lol:
  19. Jeffrey Svoboda
    Jeffrey Svoboda
    No doubt. Everything in this build seems to be about size/space constraints. Looks like it'll be about 79" to the lowest point of the fan. Maybe 81" to the blades.
  20. Eric Wanderweg
    It can't possibly still be that green down there... are these older pictures that you're dredging up a little at a time?
