Homemade 4 way hydro wedge meets it's match
Discussion in 'Chainsaws and Power Equipment' started by metalcuttr, Mar 16, 2025.
  1. metalcuttr
    metalcuttr
    western WA
    Did some trials today on the new 4 way. First thing was that the stuck log unloaders had to come off but I knew that from the previous wedge. Ran about twenty 15"ish rounds through with and without knots. Also ran about 18"-20" half rounds through with and without knots. I split with both the flat side down and up and flat up worked best. The results were pretty much the same with 4 way complete splits without any binding at all. Since the wedge is slip on and a tad loose, it can move around a bit to help keep splits free. The angled wings are actually a plus in that they tend to grab the splits and keep splitting as they try to spread. When I tried several 22" full rounds results were not totally satisfactory as some of the horizontal splits did not separate completely. All together I'm very pleased. It should be the cats meow on rounds to 15"-16" and half rounds to 20". I suspect this will be it's most useful range.
