The Woodyard Abhors a Vacuum
Discussion in 'The Wood Pile' started by Eric Wanderweg, Mar 19, 2021.
  1. buZZsaw BRAD
    I see you did the same thing I am guilty of. Start filling it with wood before its finished. :stacker:
    Great use of leftovers. Just don't hit your head. Needs a low clearance sign if I'm there! ;)
    I don't even have a roof on my shed addition...its several sheets of plywood, OSB etc. :emb:
  2. Eric Wanderweg
    The roof on this thing ended up being a big mismatch of whatever sheets I had. Some 3/4 marine plywood, some 1/2 OSB, 1/2 plywood, and one piece of 7/16 to finish it off. Not too different from your “calico” roof metal that I remember seeing. It’s crude but will work though, and it only cost me some time. All the materials were already here and some recycled from the big shed that got squashed last winter. I had gotten the bulk of the framing done yesterday and wanted to see some wood in it right away, hence the “tryout for size” before finishing it.
  3. buZZsaw BRAD
    As long as it keeps the wood dry! How is the UV resistance of that plastic sheeting you scrounged?
    My original shed is done, but the two additions don't have a "permanent" roof...yet.
  4. Eric Wanderweg
    I originally thought it was crap based on one place I used it. After a year it was Swiss cheese. But in another spot where I used it, it held up fine. I looked up above the stacks and made an observation. Where the tarp rotted there was an oak tree above it. In the place where the tarp was fine, there was a maple. So there’s something about the rain runoff from the oak… acidic maybe. Oak is high in tannins so maybe that’s it too. So in a nutshell, the free tarps work… kind of. I have enough of them so I’ll use them.
  5. Eric Wanderweg
    This takes care of all the wood that was already split and needing to be stacked. I have more red oak in rounds that I’ll have to split, then this shed will be full.
  6. MikeInMa
    Never refilled after last year's heating season.
    That's a stack of elm rounds. I suspect I'll end up noodling them.
    :emb:
  7. Eric Wanderweg
    Sans hydraulics, the chainsaw is the correct tool for that job :salute: I think you’ll be happy enough with the end product when it comes time to burn it though.
  8. metalcuttr
    metalcuttr
    western WA
    Love the rectangular splits in your cribbed ends. Good looking firewood and stacking. When I used a sledge and wedge on the big ones, before hydro, I would always split a bunch of rectangles for cribbing on the end stacks!
  9. buZZsaw BRAD
    Just curious as to why you dont do the same now that you have a hydro rather than the pizza slice splits you use for cribbing now?
  10. MikeInMa
    I dug around in FHC and found the thread when that stack of elm rounds showed up 11/21. Not having much exposure to elm, my thought was some kind of maple.
    Two reds
  11. metalcuttr
    metalcuttr
    western WA
    The pie shape is easiest to do when manipulating large rounds which is most of what I get anymore. Split the big round in half then start making pies. Also easy to split a pie around a knot. When I was sledge and wedging, I would split the edges of the round away to make a square billet then split that into rectangles. Splitting the edges away is hard to do with a splitter as the wedge will not bear on the wood or barely will. I could still split the edges with a maul or axe then hydro split the square. Or I could rethink my splitting approach entirely but, what the heck, the pies work fine and are the easiest!:thumbs:
