Egg carton fire starters
Discussion in 'The Wood Pile' started by MHL68, Nov 18, 2026.
  1. MHL68
    MHL68
    Southern MN
    IMG_20261118_050118.jpg How many of you use these kind of starters?
    I have only been burning in the house for a couple of years. But have been using these kind of starters for years for back yard fires and at the cabin. They work so good can't imagine using anything else.
    Made up a bunch more the other day over a nice outside fire. Spent the entire day sitting by the fire having a couple beverages and making starters. Gotta love being retired!
    Ended up being 88 dozen before I ran out of wax
    Wouldsplitter, BCB, Skier76 and 18 others like this.
  2. Sandhillbilly
    Sandhillbilly
    North central Nebraska
  3. Sandhillbilly
    Sandhillbilly
  4. RCBS
    I make saw noodle cup cakes. A great fire starter hack I learned is to buy one of those 'logs' in a bag that the city folks use. You can break the logs down and make dozens of mini fire starter pieces. They'll match light and burn for several minutes which is all that should be needed with dry wood.
  5. Erik B
    Erik B
    Western Wisconsin
    I also use egg cartons with wax and drier lint. I make 6 dozen at a time. It is just the wife and I at home so the amount of lint is smaller than when we had our boys at home. I don't even have to use any kindling when using these.
  6. Biddleman
    Biddleman
    River Hills of Pennsylvania
    I made some this summer for the first time. I used a few cups of pine shavings that I use for the chicken coop bedding l.
    I'll be making more for sure.
  7. MHL68
    MHL68
    Southern MN
    You are correct, absolutely no kindling needed when using these.
  8. Heptameron
    Heptameron
    Spain
    First time I'm seeing this home-made firestarters, those are cool: reusing, repurposing and practical!
    I've never done any custom firestarters and mainly stick to newspaper and dried rockrose.
  9. JD Guy
    JD Guy
    Upstate SC
    I’ve wondered what happens to the melted wax in the firebox, does it have to be cleaned out or does it just end up vaporized from the heat?
  10. Erik B
    Erik B
    Western Wisconsin
    I have been using the egg carton/lint/wax combo for years and I have never seen any residue from burning wax in the stove. It is only a couple tablespoons of wax per starter.
  11. JD Guy
    JD Guy
    Upstate SC
  12. MHL68
    MHL68
    Southern MN
    2 tablespoons per cup is what I do. I actually took one of the wife's old table spoons and bent it into an L so it works like a ladle. Ladle out 2 per cup out of the melted pot. Keeps everything nice and even and they burn for several minutes starting any splits I put in there. Never seen anything left over.
    With 88 dozen won't need to make any for many years.
  13. Butcher
    Butcher
    Been using them for some time now. Since we don't eat many eggs I often don't have enough cartons so I save the tubes from terlit paper rolls and cut them in half. Works just as well.
  14. Erik B
    Erik B
    Western Wisconsin
    I am using an old metal tablespoon zip tied to a piece of dowel.
  15. buZZsaw BRAD
    Great improvisation! :thumbs:
    Hopefully the Mrs. doesn't notice that its missing!!! :whistle:
  16. Erik B
    Erik B
    Western Wisconsin
    Thanks Brad. It was an old spoon that she was no longer using.:handshake:
  17. Skier76
    Skier76
    CT and SoVT
    Wow! Nice work! I’m using toilet paper tubes stuffed with birch bark and a chunk of candle wax. So far, so good! But I really like the idea of using the log in a bag and cutting it up. Smart!
  18. JDU
    JDU
    Perry County, PA
    I have made the egg carton fire starter filled with cedar sawdust that I got from "noodling" a split of cedar for longer shavings and candle wax.
    I like the idea of spooning it in as I just poured it over the carton and wax distribution was sketchy.
    Recently I've been making starters by dipping round cotton makeup pads into melted wax and a pinch of charcoal lighter fluid. They burn 4 minutes.
  19. MeanJoe
    MeanJoe
    Western Michigan
    Used to make a lot of those. Started to buy whatever cheapest fire starters I could find on Amazon. Might go back to making those again. I also considered strips of cardboard dipped in wax. Wood is pretty dry, doesn’t take much to light it.
  20. MHL68
    MHL68
    Southern MN
    The day spent making them was half the fun.
    Find a nice fall day and started a bonfire. Had a bunch of twigs and branches that needed to get burned up anyway. Along with a bunch of lesser wood I try not to burn inside anyway, I had a nice size fire all day. Sat and had a few beers, stared out at the lake, made some very useful fire starters, and even made lunch over the fire. Hard to beat a fall day spent that way.
    MeanJoe, sms4life, JD Guy and 6 others like this.
