Firewood saver….. Installed mini split
Discussion in 'Everything Else (off topic)' started by moresnow, Nov 10, 2026.
  1. moresnow
    moresnow
    After contemplating for a few years we decided to go ahead and put in a mini split.
    Just as I had hoped this is eliminating wood consumption during shoulder season.
    Spooled it up the beginning of Nov. planning on getting a full month of continuous use for a cost analysis.
    Its handy. Quiet. Unobtrusive.
    And keeping my place warm.
    SENA-15HF-OG Model by Senville
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    Spoiled. :p
  3. brenndatomu
    Screenshot your pics, post those.
  4. moresnow
    moresnow
    22F. Still shoulder season? :whistle:
    Maintaining nicely this morning.
    Is it wood heat type warm? Nope.
  5. wood and coal burner
    Quakertown,PA
    Did you install and charge it yourself or pay someone to do it? If you installed it yourself is it still covered by the manufacturer's warranty? I have thought of getting one for my garage/shop so I do not have to use window AC's anymore. Also, to keep the temp more constant in the winter when the wood stove fire dies out.
  6. moresnow
    moresnow
    Sooooo. Installed with a knowledgeable buddy who sells these things. The outdoor unit and perhaps indoor as well is charged as I understood? The line kit was pressurized with air only and capped from the factory.
    We fit the line kit roughly.
    Uncapped the line kit and cut it to fit.
    Re-flanged the line kit and hooked it to the outdoor unit.
    Hooked up a A/C vacuum pump and pulled it down for certain amount of time. I don't recall exactly how long! Maybe 10-15-20 minutes?
    We then waited a prescribed amount of time (15-20 minutes if I recall?) to see if the unit held pressure/vacuum. All was good.
    Hit the power and cranked the A/C as it was actually quite warm that day.
    Worked perfectly.
    Also turned the unit to the heat setting and cranked it up. Perfect.
    Been flawless since.
    Filed the warranty through my buddy who has the dealership arrangement with the distributor/manufacturer.
    Honestly the warranty on these things appears about useless in reality.
    If it goes down early, I may get some replacement value. Maybe!
    I'm into the unit, including installation, for $1770.
    Just happy to have heat now and not have to install a window air in the spring.
    Yes. We have been using a window air for over 30 years! Many window air units in that amount of time.
  7. wood and coal burner
    Quakertown,PA
    Thanks for the reply, thinking a little more about this now.
  8. yooperdave
    moresnow thanks for the thread.
    As it so happens, Senville is the exact same brand I have decided on purchasing. It'll be used in a newly built sunroom.
    I retired from HVAC (install) and phoned them to make sure when I chose the DIY route, that the warranty would still be valid.
    They said 'Nope".
    After further discussing what I did, what licensing I have, they instructed to take a picture of the license when submitting the warranty registration and all will be satisfactory.
    Because of the season's temps, I delayed the purchase/install until next year.
    metalcuttr, MikeInMa and moresnow like this.
