Bottom Rows
Discussion in 'The Wood Pile' started by FortySix&Two, Nov 13, 2026.
  1. Michigander
    Michigander
    Macomb Michigan
    That is a beautiful stack of wood. How high is it?
  2. RCBS
    No bottom row issues for me with a single layer skid. My tarps usually give me a little bit of awning on either side.
  3. The Wood Wolverine
    The double wide splits go up about 6’, then on top in the middle I go about another 12-18”.
  4. Scotty Overkill
    A little splash ain't gonna cause you issues so long as the wood is off the ground and has air flow. I'm almost 7yrs ahead on my stacks, now mind you that wood sits in the stacks for 5 to 7 YEARS.....so even though I have everything off the ground and top-covered, some of my outer perimeter wood does get a little mushroom growth on the weather side (namely on the sapwood band, if at all) but that's literally it. Nothing inside the stacks is affected so long as the top cover isn't leaking (I use EDPM rubber roofing so it does very well at keeping the water out for many years).
  5. buZZsaw BRAD
    Those cages are nice if you have the room and even equipment to move them. I've made similar sized bins out of pallets in the past mostly for nuggets and chunks.
  6. MeanJoe
    MeanJoe
    Western Michigan
    I don’t really have the room but I have a Skidsteer so moving them isn’t an issue. I may try to stack them two high next time I fill some.
  7. buZZsaw BRAD
    The guy I used to cut for PT stacked them three high.
  8. MeanJoe
    MeanJoe
    Western Michigan
    If I didn’t cut the front off I would as well. I’m concerned the corners would buckle. I cut the front so it’s easier to stack wood in and take back out. Maybe I’ll too picky.
  9. buZZsaw BRAD
    Not picky IMO. These were loaded from a conveyor (sometimes by hand) and get dumped/loaded with his skidster. Neatly stacked they're probably heavier.
  10. MeanJoe
    MeanJoe
    Western Michigan
    I cut wood short so I can stack 3 rows per tote. I mark logs between 12” and 14”. I used to cut everything to 20” at our last house but I didn’t have quite as many totes to work with there. More logs to work with but easier to handle at 12-14”.
