Bottom Rows
Discussion in 'The Wood Pile' started by FortySix&Two, Nov 13, 2026 at 4:28 PM.
  1. FortySix&Two
    FortySix&Two
    Charlton, NY
    Do you guys do anything special to keep the bottom couple of rows from getting "splash" off the pallets? Does it impact overall drying time as long as the rows are top covered and the middle part of the pieces are staying dry?
  2. Eric Wanderweg
    I don't do anything special and I've noticed that it does make a difference. Sometimes I'll stack pallets on top of pallets if I've got enough. The extra elevation helps a little. I've seen some guys go a step further and put pallets on top of cinder blocks. I think the higher you can get them, the better you'll be in terms of both splash and air flow.
  3. ironpony
    ironpony
    Mid Ohio
    The bottom row is the sacrifice you make to the firewood Gods for allowing you to sacrifice his trees
  4. FortySix&Two
    FortySix&Two
    Charlton, NY
    I do have some currently drying for a couple years on double stacked pallets. My wood currently drying outside will be moved into the woodshed for a minimum of another year of drying time as I consume wood, so it's probably fine.
  5. Eric Wanderweg
    That sounds like a very solid system. Eons ahead of the guys that just toss their split wood onto the lawn, cover it with a ratty tarp, then haul the fungus farm splits into the house come Thanksgiving :hair:
  6. FortySix&Two
    FortySix&Two
    Charlton, NY
  7. NC-PersimmonDude
    NC-PersimmonDude
    Good source of pallets so I am a double stacker too. Does seem to work better/less rot, especially if due to space constraints your pile has shade for more than half a day. Over time the firewood gods get to have the bottom pallet row! I also once did old log rows/skids and one layer of pallets on top but that led to some stack shifting over time and that negated the elevation advantage.
  8. JDU
    JDU
    Perry County, PA
    I am currently looking at a bottom row wood fire in my insert as I write this. It's dirty with dead grass being blown into from mower, and discolored from being bottom row wet and dry cycle, but burning nicely! Like the others have said, just part of the deal.
  9. Jeffrey Svoboda
    Jeffrey Svoboda
    I just leave most of the bottom pieces to be restacked come spring. Usually on the top of the next years stacks. More than ready for the following year.
  10. buZZsaw BRAD
    Most of my racks are over 10" off the ground so not much splash factor. The lower splits do get more weathered from this. The top cover hangs over 2-3", Most of my stacks are top covered with Ondura roofing panels I bought from Lowes. Sometimes I'll lean a plywood scrap against the bottom to deflect water but not often.
    My latest bin/rack is 18" off the ground so a non issue.
  11. Jeffrey Svoboda
    Jeffrey Svoboda
    Sounds like you're losing valuable storage space. :emb:
    MikeInMa, eatonpcat and buZZsaw BRAD like this.
  12. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Gave up on pallets and use totes now, but did/do use cinder blocks under them, other than a few that house wood for a neighbor and friend. Neighbor hasn't used hers for a couple of years so I see if she wants to sell it back to me.:cool:
  13. buZZsaw BRAD
    I see where you were going with that! :rofl: :lol:
    In this case no as it was a 4x4x8' rack for nuggets using the same footprint as the old one. Plus its saving my aging back and improving airflow.
  14. The Wood Wolverine
    I don’t have any issues stacking on plastic pallets but my splits go right to the edge. And I’m 5-6 years ahead so they are there a while.
    Maybe keep yours at that edge or a bit over and pyramid them going up?
  15. MeanJoe
    MeanJoe
    Western Michigan
    I stack on a concrete pad. Thought about getting pallets to put under the splits but never did. I assume the bottom row will be a little wetter l. I can always stack the bottom rows in a tote for an extra year but I bet it will be a non issue.
  16. buZZsaw BRAD
    Plastic pallets maybe an option? Maybe stack on 2x4 sleepers?
  17. In the Pines
    In the Pines
    I evolved into double stacking of the block pallets. mainly due to the yard swamp
    I think it allows more air flow from the bottom and keeps the bottom layer a little more dry
    It definitely keeps the wood away from the water that pools and doesn't drain quickly due to clay pan in the yard.
  18. Canadian border VT
    Out back the pallets are on an old gravel road so the splash is less.
  19. Ctwoodtick
    Ctwoodtick
    Southeast ct
    I think the bottom row will be a little wetter than everything else, but it will be far from being unusable. That piece in the stove burns a bit smokier I suppose. No biggie.
  20. MeanJoe
    MeanJoe
    Western Michigan
    Thought about it but never did. In an ideal world I’d have more cages to stack in and that solved the issue.
    buZZsaw BRAD and eatonpcat like this.
