Stihl USG grinder
Discussion in 'Chainsaws and Power Equipment' started by Rope, Nov 5, 2026 at 10:38 AM.
  1. Rope
    Rope
    Alaska
    Just purchased one to sharpen 404 harvester chain. Go figure had to modify it to fit the 80 gauge drivers. Lucky it was just a shim job with washers. I did a good job all the cutters look good. I need to figure angles out a bit. I only cut spruce with it. I think it’s optimized for hardwood that’s probably not frozen. Only thing less favorable is it’s a 12mm arbor vs the standard 7/8 that most wheels are. Currently using a Belsaw/Frowly wheel.
  2. Rope
    Rope
    Alaska
    I have a little more time on the grinder. It is built well, it's pleasant to sharpen chain on, it is decently fast on the .404 - 89 driver harvester chain. Currently playing with angles to see what works on frozen spruce. My only comparison is a Simington 451C square grinder (had) and I have a Silvey Razor-sharp II for square grinding chainsaw chain, I can only cut .50- and .63-gauge chain with it, hence the purchase.
    I decided on the USG as it was at the local saw shop and anything else I would have had to order online. But could not find if they would accommodate the .80 gauge. Saw shop owner said bring a loop and we will try it on one of his USG, before buying one.
    Anyone have one of these, and have any pro-tips? Anyone use/sharpen or have pro-tips on .404 harvester chain?
    Jeffrey Svoboda likes this.
  3. Jeffrey Svoboda
    Jeffrey Svoboda
    Haven't heard .404 mentioned here in years. Ope probably has some topics on it.
    Rope likes this.
  4. Rope
    Rope
    Alaska
    I'm guessing that not to many are using harvester chain, it was a shot in the dark. Nonetheless worth asking. I have 3 cut to see what my machine likes. It's just a matter of time to get it figured out. Stihl has a chart that comes with the USG that gives angles for various chain. I have a starting point.
