GCI60 Ignitor Replacement (Bonus Agitator Replacement)
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Skier76, Mar 2, 2026.
  1. Skier76
    Skier76
    CT and SoVT
    This is probably going to be pretty similar to the freestanding GC60 and Enviro M55 variants. Oddly, not a ton of info out there on this procedure.
    Backstory: I was flying to NOLA on Sunday; gave the stove a solid deep clean Saturday….and loaded a bunch of pellets in the garage for my wife. We had a big snow storm coming. I get a call Monday AM. “The stove isn’t on…and there’s a big pile of pellets in the burn pot.” My wife was a trooper and we did some troubleshooting over FaceTime. Long story short, the ignitor was cooked. (She did get it running via propane torch!)
    I ordered a new ignitor and agitator from stoveandgrillparts.com. I think someone here posted that link awhile back. Thank you! The cost of the OEM ignitor is preposterous($699!!!!). This one was just a tick under $120 shipped.
    The installation was pretty straight forward. I thought I would maybe have to remove the auger drive motor, but I didn’t have to. You can get to the single Torx T15 (I think?) bolt that holds the ignitor in place. I used a 1/4” ratchet and an extension. There’s not a lot of room back there, so it was a lot of 1/4 turns to back it out. It has two wires connected to it and two vacuum lines which were zip tied from the factory. The mounting hole on the new unit didn’t line up perfectly, so it took a little finagling. But for the price delta with OEM, not a big deal at all. It added maybe 2-3 minutes to the job. I did test the new and old one with my multi meter on ohms and the old one was in fact bad. I suppose it’s better to test things before ordering parts, but I was pretty confident what the issue was here.
    Since I’ve noticed the agitator was seeing a little wear as of late, I decided to order one of those as well. Ironically, same price as the ignitor. (OEM is $249) As you can imagine, the install was straight forward.
    Stove lit right up after I got things buttoned up! I’d say it lights quicker than before. That being said, the original ignitor lasted over 10 years. I can’t recall exactly when we had the unit installed, but it was over 10 years ago…maybe closer to 15? So a good run! We’ll see how this one holds up.
  2. BHags
    BHags
    Massachusetts
    Nice stove!
    jtakeman, Skier76 and imacman like this.
  3. imacman
    imacman
    Denver, NC
    Looks like you got $$ worth out of both parts. Nice job.
    jtakeman and Skier76 like this.
  4. Skier76
    Skier76
    CT and SoVT
    Thanks everyone! Definitely got some life out of both of those parts.
    This stove has been really reliable over the years. These are the first parts I’ve replaced. Only other upkeep (aside from cleanings) has been a bit of grease in the bearings for the blower fan that circulates the air.
    jtakeman, BHags and imacman like this.
  5. Skier76
    Skier76
    CT and SoVT
    Well, the new igniter went south. My attempt at humor hear: Old igniter, 10 years, new igniter…10 days.
    Anyways, the part had a 90 day warranty. I called up the placed I purchased it from, filled out a form online and one has been shipped out no charge.
  6. jtakeman
    My turn for some new parts for my Enviro(Omega). You all shamed me into it, My Burn pot grate was in pieces!! I was having to play puzzle on every stove clean with it. Plus the liner was cracked(has been for a few seasons).
    Looked at just replacing the 50-1696 burn pot grate and burn pot liner. But those 2 would be over $260. Wound up getting the after market kit that had everything for the burn pot(liner grate agitator and the burn pot holder) for $239 plus shipping. Good thing I did because the liner would not fit in my old holder without mods!! They are for the M55 FS and are slightly different but seem to work OK. Of coarse I kept my old stuff!! I might patch them back together as spares!
    I'm not a fan of the aftermarket agitators, They bend like crazy. But I will straighten it for a spare. May get a new OEM the next time I need one. Or make my own again? I may also make my own burn pot grate too. Make it out of stainless steel and see if it will last longer!
    brenndatomu, Skier76 and imacman like this.
  7. Skier76
    Skier76
    CT and SoVT
    Nice job! I’ll keep an eye on that agitator going forward.
    Well, the replacement igniter unfortunately doesn’t get hot enough. I’ve done a bunch of testing, but the stove won’t lit off using it. I also put in another burn pot liner I had; same results. I’ll reach out to the company again. They’ve been easy to deal with. Long story short, the ignitor heads up (it glows), but doesn’t get hot enough to light the pellets. Airflow is good around the unit based on my testing.
    imacman and jtakeman like this.
  8. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    I ordered from Stove parts the first time and was very pleased! This time I ordered from Moutain Hearth products and the first one was damaged and they told me to fix it, the second one the wiring was different! Glad you got your stove all fixed up! How tight do you have your agitator chain, I tightened mine up tonight as it seemed to have some slop in it?
  9. Skier76
    Skier76
    CT and SoVT
    Unfortunately, the second ignitor is no longer working. Reached out the seller via e-mail and will keep you all updated.
    The chain definitely has some slack in it! Maybe just the way it was designed?
    brenndatomu, imacman and jtakeman like this.
  10. Skier76
    Skier76
    CT and SoVT
    Well, the saga continues! After a call with the seller, they feel the vacuum pump may be the issue; not enough airflow and causing the igniter to burn out. I bought the pump and a new igniter on my dime. It shipped April 1st and is still stuck in the USPS system. I’ve messaged the seller and haven’t heard back. Looks like I’ll be calling again Monday.
  11. Skier76
    Skier76
    CT and SoVT
    Long story short, USPS lost the package. The seller resent the items. So, I’ll find some time to install and test…now that it’s almost air conditioning season…ha!
  12. Skier76
    Skier76
    CT and SoVT
    And here we are again! I got around to putting the pump and new ignitor in. Stove would not light off. Pulled the stove out on the rails again and found the fuse for the ignition circuit had blown. New ones should be here today. Hoping this solves it. But I am concerned as to what caused that fuse to pop in the first place.
    brenndatomu and imacman like this.
  13. imacman
    imacman
    Denver, NC
    Maybe the original ignitor is still good, if the fuse was blown.
    In the Pines and brenndatomu like this.
  14. Skier76
    Skier76
    CT and SoVT
    Tested the ignitor and it was faulty. New one on the way.
    I also picked up some connectors that will allow me to see how long the ignitor is drawing power. In speaking with the company that sold me the igniters, they stated they have seen some GC60’s where the control board goes bad and keeps sending power to the igniter even after the ignition cycle is complete.
  15. jtakeman
    IIRC the start cycle is like 5 minutes long. The air pump is also on the same circuit and you should be able to hear it running if the board is stuck/fluked.
  16. Skier76
    Skier76
    CT and SoVT
    Thanks! I put a new pump in as well. Hoping this new igniter works and I can see what’s going on after the ignition cycle.
